Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsu VS-5043 All of a sudden it acts like it not plugged in. No power light at all-won't turn on manually or with remote. Yes it is plugged in to an operating circut
  • Mitsubishi Master
  • 8,457 Answers
Ur Power ic inverter board is dead.
u need a new one.
Posted on Aug 25, 2009
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Manual for mitsubishi vs 5043 cannot program for
If you go into the main menue with the Mitsubishi remote, there should be a set up icon for programing stations. It should give you a selection for cable and or standard tuning. Select cable then press auto program.
Hope this got it done,
Skyassoc
Jun 19, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsu vs60603 menu ?
actualy the only wat to reset is to unplug the power cord for 1 minute the plug it back in.
Aug 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
50" Mitsubishi
Check the 5 volt pico fuses on the center board. F9A05 is most likley open. This would indicate bad convergence amps. The two Convergence amps and fuse should be replaced.
Josh
Mar 02, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi ws65909
Yes,but first it is necessary to repair the problem = replace
both STK392-570 IC's.............Then use remote to adjust
convergence............."inside the tv" is called servicer menu = adjust after repair is complete.You can expect to replace IC's
every five years or so.......................T.
PS Try to match your problem thread model # to actual model #
ie. VS-5043 does not match WS-65909........T.
Nov 25, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Big Screen TV VS 5043
depending on the model it could be serveral things. it could be convergence ic's gone bad or a problem with the power supply, something is shuting it down . contact mitsubishi for your nearest sevicer
Oct 19, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
