Question about HP Officejet 5610 All-In-One InkJet Printer
Hp 5610 paper jams
Printer keeps jamming when I try to print on card stock or any type paper when print more that 3
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
  • 7 Answers
SOURCE: wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Posted on May 30, 2009
  • 54 Answers
SOURCE: HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Posted on Sep 04, 2009
  • 20 Answers
SOURCE: My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Posted on Sep 06, 2009
  • 120 Answers
SOURCE: after setting the paper type to card stock to thin
This happens to be one of my least favorite printers.
Here is my suggestion:
Open up the cover and remove all 4 of the imaging units (with the toner cartridge). Also, remove the Fuser. While removing them, look for any bits of paper that may have gotten missed while clearing the jam.
Replace all of the items above and see if the printer still has a paper jam. It shouldn't.
Since, I assume you are manual feeding the card stock (the lower drawer doesn't allow for card stock to be used), look at the manual feed opening. There should be a small metal piece about 3" wide and less than 1/4" thick. Make sure it's attached properly. Ours unseated itself and is continuing to cause manual feed issues. This can be fixed but requires a good portion of the printer to be opened up to reseat the little metal piece.
Hope this helps.
Posted on Oct 16, 2009
We are trying to print on a card stock ,110 lb. , 8.5x11 Paper keeps jamming. Will this printer work with card stock?
It will only work if the printer supports feed through from the back. If the paper has to go in the same side of the printer that it comes out it will jam.
Mar 20, 2011 | HP Officejet J5780 All-In-One InkJet...
Trying to print on card stock paper and get a paper jam Is there a setting for printing on card stock paper?
Hi Fuller90
Read your issue.
1. Kindly check the thickness of the paper. If the thickness of the paper or the card is more then normal paper, you will experience the paper Jam on this printer model.
2. You can try this step..... Take the Power cable out from the printer.
3. Press and hold down the power button for 35 seconds.
4. Now release the button and then plugin the power cable.
5. Check your issue.
Aug 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
Printer jam
Make sure tray 1 is set for "auto-sense/full sensing".
Make sure the feed rollers are clean or just replace them
May 06, 2010 | HP Color LaserJet Enterprise CP4025dn ...
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
I AM TRYING TO PRINT HEAVY STOCK CHRISTMAS CARDS -
If its heavier than 60 to 105 gsm (16 to 28 lb), then your printer can not take that type.
HP Specifications
Unless there is a manual feed on the back, the paper won't be able to bend well inside of the printer, hence the jam.
Nov 29, 2009 | HP Office Equipment & Supplies
My hp officejet 5610 all in one keeps saying paper jam and there is no paper jam
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab47
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 5610v states 'paper jam' and there isn't one - how to reset?
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Officejet 5610 All-In-One InkJet...
Wont print on card stock, legal paper- keeps jamming
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
5610 will not print on color paper
I'm wondering if the paper weight and/or size is exceeding the printer's specifications. The paper tray specs on HP's site says it will take up to 110 lb card stock, but as far as paper stock, it can take only up to 24 lbs. Have a look at the printer's product specifications page and see if this could be the issue:
Product Specifications page
Sep 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
