Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet clothes washer will work for the first 7 minutes and then F20 (Water Inlet Problem) flashes. I've tried unplugging it overnight and that didn't help. It's getting water fine during the first 7 minutes. I've also checked and pulled the drain hose out of the drain pipe.
  • royceann Jun 30, 2009
    Regarding recommendation #4, what is a wire harness?
  • royceann Jul 14, 2009
    My plumber knew what the problem was!!! We had flood control steel hoses on it that were malfunctioning. Every time water went through the hoses, it indicated there was a flood and the hose shut off the water supply.
    Thanks for your help!
  • 111 Answers
F20
NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED. The pressure switch is not tripped after 6 minutes. Possible Causes/Procedure If there is no water in the unit: – Make sure that both valves at the water source(s) are turned on all the way. – Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. – Verify inlet valve operation. If there is water in the unit: – Verify drain pump operation. – Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Verify there is not a siphon problem. 2. Press PAUSE/CANCEL twice to clear the display. The machine will drain for 3 minutes before unlocking the door. 3. Unplug washer or disconnect power. 4. Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU). 5. Check all hoses for possible leaks. 6. Plug in washer or reconnect power 7. Verify pressure switch operation. 8. Verify CCU operation by running a Diagnostic Test or any cycle.
Posted on Jun 26, 2009
  • Joe Povoas Jul 13, 2009
    its the full wiring of the unit , make sure that the pressure switch hose is not leaking is a very commom problem
What does it mean when my duet washer flashes F20?
F20 is a No Water Detect error.
It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
* If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
* If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: Duet_Service_F20_error
Hope helps.
Sep 24, 2011 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Code problem on the machine is F20
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
also, those flood prevention hoses they sell you don't work well with front load washers
Jul 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Flashing error code F20
wer
Sorry to read about your problem, I hope this helps you out.
F20" on display
water supply)
1. Are water faucets completely turned on?
2. Are screens at inlet hose connection to washer
clogged?
3. Are water inlet hoses kinked?
4. Are water inlet hoses frozen?
if this issue's are ok you may want to contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F20 appires on the time display
The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is:
If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Thank you
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the F20 message mean??????
Well the error F20 on display means (Water Inlet Problem, no water or insufficient water supply)
You can please check the following -
Post comments for further help or information..........
Good Luck!!
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting F20.
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Right befor it goes to rinse mode cycle if flashes F20. This is a new machine. I never used it. This was the first test I did.
F20 = NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
#1 cause = Make sure that both valves at the water source(s) are turned on all the way.
else
valves.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting a F20 code?
“F20” on display
water supply)
Nov 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Whirlpool Duet GHW9150P Front Load Washer Logo
293 people viewed this question
Dan Webster
Dan Webster
Sal De
