Question about Euro-Pro NV31 Infinity Vacuum
Can't find a belt!
I've been searching everywhere for a belt, and I can't find it anywhere! I've been to target and walmart and home depot and no one!
    Top Expert:
  • Euro-Pro Master
  • 80,407 Answers
Go to a vacuum service store, they can match it up, they have hundreds of belts. check your local phone book under "Vacuum cleaner parts and service"
Posted on Jun 26, 2009
  • 458 Answers
NO PARTS FOR SERVICE JUNK Vacuum
Posted on Aug 05, 2009
I need a belt for a shark model #v131optn power pet upright bagless vacuum
Mark, Google search for a near by vacuum shop and stop in and get a belt or google search your make and model, Belt. Check the attached links for replacement belt, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.sharkclean.com/parts/0/all/484/replacement-belts-2
Vacuum Cleaner Belts Walmart com
Vacuum Cleaner Belts at Ace Hardware
Jul 14, 2016 | Shark Vacuums
WHERE DO I FIND A REPLACEMENT BELT FOR MC V7305
Any Vacuum shop should have this, and depending where you live, canadian tire, walmart, target, Sears should have the belt.
If your not close to any of those places, let me know and I will try to help out better.
Good luck,
Mark
bartmkh@yahoo.ca
Nov 07, 2010 | Panasonic MC-V7305 Upright Vacuum
Brush won't rotate
Hi!!
Check belt, probably broken. it is located on one of the ends of the brush, you may need to remove a couple of screws to gain access to it.
Replacements can be found at Walmart, Home Depot, or an Authorized Kenmore Service Center.
Don't forget to rate this post. Good Luck!!
May 27, 2010 | Kenmore Progressive Bagless Upright with...
Unable to find recomended cleaner for floor mate, what can I use
Do NOT use ammonia...it will destroy the seals. #1 NEVER leave solution in the tank...and clean everything after every use. Lowe's and/or Home Depot have Bissels cleaner for the Hoover Floormate...also check Target and Walmart's sweeper dept. If ALL fails, you may use Zep Pine Cleaner (Home Depot) in a diluted 2oz. to 1qt. water...filling ONLY the little reservoir with this dilution!!!!! Good Luck.
Dec 28, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Roller bar belt broke on my dc17 animal. how do i
This belt isn't available at your normal retail stores like Walmart or Home Depot. You can try your local vacuum repair shop, but not all vacuum shops carry Dyson parts. The best bet is online. You can get this belt here at this link and shipping is only $1.99. That might be worth it rather than driving all over trying to find that belt.
Dyson DC17 Replacement Belt
Nov 08, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
We have had three belts break on your hoover vaccum cleaner u5472-940. It is easy to replace, you just remove the plastic part over it, put belt on wheel and then put it back on. Any idea on why the belt...
sometimes when you buy belts from the walmart or target, they are not at the correct specification and they brake as soon as you turn on the machine. i would suggest that you buy these belts from the company.
Jul 18, 2009 | Hoover F6021-900 Steam Vacuum
The brush isn't spinning
the belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
Jul 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
Need belt for Everstar 5990 vacuum cleaner
I just replaced the belt on my Everstar VC-9550 and it works fine. I found it at Home Depot for $3.99. The belt is sold under Vac Belts item No. 51007 (Designed to fit Bissell Uprights, Style 7,9,10).
Apr 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Euro-Pro NV31 Infinity Vacuum Logo
281 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
