Question about Microsoft Xbox 360 Console
No display, perfect sound
The screen started flashing and stuff and I was so close to an acheivement. So i tried to fix it by turning the lead from hd-tv to tv. My console reset. That was depressing. Then when my console came back on it flashed and my tv displayed; Can not display this format. I have tried everything. Different tv and cable. Pissed off now.
Going to buy new xbox. ******* scumbag microsoft. I will find you Bill Gates... someday... and then...
  • 60 Answers
It was caused by the graphic card
Posted on Jul 25, 2009
My TV screen appears for a second then turns black, then a few seconds later appears again and the turns black again. The channel sound is perfectly fine. My Cable company tried everthing and it still...
If the tv isn't fully shutting down. but just flashing on and off then it
sounds like a backlight supply fault.
All LCD screens have what can only be described as micro flouro lights inside the screen module.
it is possible that the power supply is faulty causing them to flash on and off every now and then. or the tubes themselves are damaged.
to confirm this..
Lay the tv down flat on its back and power up in a well lit room
get down close to the screen and look across it at a acute angle
now if the black screen looks like it is still displaying an image then it's definatley your backlights!
in which case it could be a simple fault in the power supply.
so if your feeling confident in yourself i can talk you through what to look for in the supply..but try this first and get back to me.
hope this helps,ben :-)
Jan 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
The blower will not run steady unless choke is 80 persint closed i had to move choke up and down to acheive this
Hi jwoods733, I think we should start simplest and least expensive first. Sounds like a simple adjustment. I am assuming it starts ok.Turn The high speed counter clockwise(furthest from the engine) about 1 half turn. May have to play with a little one way or the other. This should fix it. If it doesn't replace fuel filter. It is in the fuel tank, fish it out with a wire bent into a u shape. Hope this helps ya.
Dec 09, 2010 | Echo Garden
I had problem with my HP laptop as i start power it gives light signal but nothing get display on the screen. i try to fix problem but i could not do it as nothing display by screen and don't know which...
remove battery and power plug hold power in for 50 seconds the leave battery out hook backup power lead and try turn on. My tech team and I can help lots with PC stuff it would begreat if you could ask any PC questions you have here so we can discuss itproperly http://www.mypcmates.com
Nov 11, 2010 | Computers & Internet
Screen started to flash different colours now no screen at all
the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 01, 2010 | LG Secret ? KF750 Cellular Phone
Pioneer PDP 4330HD display flashes red LED 4 times
Just seeing if you had resolved the problem as my mum's Pioneer PDP-433HDE which she bought back 2002 has developed this same fault.
It has been a perfect TV and done very well with plenty of good use, but I have a feeling the cost of repair - even if it is possibale will be costly.
Cheers
Nigel
Mar 13, 2010 | Pioneer PureVision PDP-4330HD 43 in....
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
My gamerscore shows up on the "my xbox" screen but....
Sounds like someone has modded equipment, or your victim of a malicious other. Now I have idea of why this could happen. Your memory is full, you've been hacked, You have modded your 360. Of course it seems like your 360 is automatically downloading things from live and is deleting your items, this although unlikely is a suspect. Here's a few part solutions:
1.If you've modded your 360 I'm sorrry I can't help
2.If you've givin' your information out recently, then you should call microsoft and they'll lock your account while they investagate
3.Delete some items
4. Disable live from automatically downloading things
Then again this sounds more like a problem eminating from the system itself, You may have to trade it in, But if all else fails tell Microsoft. Good luck
Dec 30, 2008 | Microsoft Xbox 360 Console
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
 John.
Aug 31, 2007 | Nikon Coolpix S4 Digital Camera
Microsoft Xbox 360 Console Logo
88 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
