Question about Refrigerators
Edgestar Dual Wine Cooler
Edgestar are the WORST products anyone can buy. I have a EWR320 dual zone wine chiller. It broke down after only a few months. I had to pay $50 for it to be sent back because they refused to send me a new one and allow me to box up the bad one and send back once received. They sent me a refurbished unit, that had damage to it, that broke down after a few months; The fans stopped working, the LED display on one side starting flashing until it finally went out. They refused to send me a new one OR repair it. They sent me 2 new LED displays, no instrustions, to figure out myself. I was able to replace the LED displays, unit still did not work. Called Edgestar again, they said ALL they can do is send a new circuit board, without instructions, best they can do! So now what? I'm 10 days without a wine chiller, already had 4 bottles spoil because the unit broke down.
  • Refrigerators Master
  • 3,092 Answers
Well... it is tough to get wine to spoil.
Keep it out of the sunlight and don't get it really warm
(after all... is just grapes that have already spoiled...
I'm just saying).
I bought the VERY EXPENSIVE Kitchen-Aid
48 bottle... took the 5 years & about another month
for the evaporator FAN to rub a hole in the evaporator aluminum return line (made in USA (opinion: junk)).
KITCHEN-AID never even returned a call or e-mail.
Handling circuit boards: You MUST WEAR anti-static
wrist straps when handling them... ELSE you could be popping those semi-conductors like POPCORN.
The only other REPUTABLE source of information I have ever found on EDGESTAR (very helpful) were the folks at
Compact Appliance.
https://www.compactappliance.com/edgestar-wine-coolers/
ESD wrist-strap
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Posted on Mar 13, 2017
5 Suggested Answers
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
  • 534 Answers
SOURCE: Wine cooler FWC20T is not working , purchased 4/2009
Mike, what I would do is get a stick of dynamite( not really) Go to an appliance parts house with the model and serial # of the unit. You may still be able to purchase the board in question from them. If they can't help you I would find a store that sells wine coolers and ask them. Unless the company you bought this cooler from had a patent on the circuit board then they are mostly generic. You may have to wire the board up a little different but the new board's information paperwork will tell you the wiring diagram for the unit.
Good luck hope this helped you in some way
Dave
Posted on Jan 29, 2010
SOURCE: Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Posted on Jul 13, 2010
aaronbeth
  • 110 Answers
SOURCE: How do I set my
Do you have electronic controls?
Posted on Jan 29, 2011
Will not cool to correct temperature as set
check the air exchange under and at back of unit if its to hot or dusty will effect how unit preforms if good and clear possible thermostat or motherboard circuit last would be low on freon
Aug 16, 2016 | Whirlpool 22" Dual Zone 38 Bottle Wine...
The left side exterior gets too hot to touch at times,is this normal?
Yes it can get quite hot, remember there is a compressor running in there.
Aug 15, 2016 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Beeping at times?
Temp OK !?? door shut all the way !?? any obstruction preventing door from sealing ?? is unit Level ??
Mar 15, 2015 | Koolatron WC18 18 Bottle Dual Zone Wine...
Bottom level of wine cooler frosted up. Trying to defrost. What is the problem?
It sounds like your thermostat is set to low, if there is a fan check it. That can also happen for a while before it quits working if there is a refrigrent leak.
Jan 11, 2015 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
Edgestar wine cooler eh error code
You can download the owner's manual at: http://www.edgestar.com/TWR215ESS-EdgeStar-21-Bottle-Dual-Zone-Wine-Cooler/TWR215ESS,default,pd.html?cgid=Wine_and_Beverage-Wine_Refrigerators
Apr 10, 2013 | EdgeStar TWR181ES
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
