Question about Coleman 10' X 10' Sundome Tent 9160K101
Coleman PML 9000 Spotlight won't charge
I plugged my 110 volt AC adaptor into my PML 9000 and left it to charge for 8 hours before I noticed the indicator light was not lit. The spotlight does not turn on or illuminate the lamp.
  • Jason Jun 10, 2012
    Yep same problem here, tested with multimeter on battery terminals, ac adapter and charging board all with a positive test. I think its the charging board...
    pretty sure its the charging board, mine did the same thing and Ive been testing everything with the multimeter
2 Suggested Answers
astever09
SOURCE: Battery won't charge on 1million candlelight spotlight pml9000
Replace the battery, Lowes sells the sealed lead battery's for $14.95. Check in the section they sell 'EXIT' signs the battery number you will be looking for is #30128 made by Utilitech.
Step 1. Unlock the bulb careful not to pull too hard to prevent snapping off the ground wire for the bulb and unplug the 'black' and the 'red' wire from the battery terminals.
Step 2. Locate the 2 screws on the side in the grey area use a P1 Phillips screwdriver a P2 will not fit.
Step 3. Carefully pry the 2 half's apart dont pull too hard but just enough to allow the battery to slide out.
Repeat the process in reverse to install the new battery.
Posted on Apr 22, 2012
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
I replaced the battery in mine(coleman powermate) for 10 bucks but you have to be careful in how you disassemble it and put it back together. Batteries sulfate after awhile like a car battery.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
Can i use a coleman ac adaptor model 5232f640 for charge a car battery
Isn't that the power cord for a Coleman 40 qt Powerchill Thermoelectric Cooler? Without the proper equipment, you take a chance of over-charging and blowing up your battery as it would be a direct current with nothing to regulate it and no needles to let you know how much of a charge it has.
Why not catch a ride down to AutoZone and buy a NOCO/180 mAh 12 Volt solar battery charger (that's right, solar power charger) for less than $25? It comes with 8' of cable and suction cups to mount it on the car while it charges with sun light. Neat little things for sure. I own two.
Sep 14, 2013 | Electronics - Others
I need to buy a power cord for the 11-410
just make sure the specs for the replacement plug is correct:
AC ADAPTER
input: 110-115V 60Hz
output: 12V 500mA
pin size that plugs into the unit ~ 9mm or a bit tad over 3/16"
with that adaptor, it takes up to 36 hours to charge it up to FULL
with a comparable DC adapter, it takes only 8-10 hours
Dec 17, 2012 | Power Center Jumpstart 11-411
Looking for a 120V to 12V charger for a Professional"s Favorite 17.5 million cp spotlight.
You should be able to use any AC adaptor that puts out a 12 volt DC current and has correct polarity. Based on the estimated size of the battery powering your spotlight, you probably will want a charger that provides at least 1000 mA of power--the charger that came with my ThorX 10 million cp spotlight puts out 1500 mA to charge the two batteries in that light. A lower amperage rating will increase the amount of time it takes to charge your light, but it should still work.
You can find a replacement charger at Radio Shack, which sells chargers that can be fitted with a variety of different tips. However, you might be able to find a cheaper universal charger with a tip that works at a discount store like a Walmart, or you might get lucky at a thrift shop or second-hand store and find a 12v charger that will work with your light. 12 volts is a common output for a lot of different devices, so it shouldn't be hard to track a replacement down. Just make sure you have the adaptor tip polarity correct, or else you could make your battery explode if you try to charge it with reversed poles.
May 25, 2011 | Camping, Backpacking & Hiking
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3...
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Nov 12, 2010 | Vector 20 Million Power Series Spotlight
Charger or ac adaptor not working?
Check the adaptor with a multi meter, 110 volts, if no get new charger as I did
Jan 25, 2018 | Drills
I DO NOT HAVE THE POWER CHARGING CORDS... ONLY THEAIN PART OF THE LIGHT/INFLATOR . WHAT POWER SUPPLY CLORD IS USED?
On the side of the unit is a small black flap that covers two prongs that you can plug a standard 110-120 volt extension cord into which will charge the unit. There are 3 read lights and 1 green lights on the top that lets you know when it is fully charged. The 12 volt charging cord is basically a cord that has 2 cigarette lighter plugs. One plugs into the unit and the other plugs into a power port/cigarette lighter plug.
Jul 16, 2010 | Vector 1 Million Power Series Spotlight &...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
897 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
David Payne
David Payne
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
