Question about Metrologic Instruments MS7120 ORBIT Barcode Scanner
Metrologic Orbit Wrongly Scan Barcode
I've Metrologic Orbit 7120, sometime it scan barcode wrongly,
eg: barcode is 1000, but it display 11000, 1200-122, it display 1200&122 and automatic beep & scan out the no when in standby mode
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
Posted on Aug 23, 2007
bluegreenash
  • 661 Answers
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Posted on Oct 04, 2007
SOURCE: Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Posted on Oct 17, 2007
penmobile
SOURCE: Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Mar 20, 2009
SOURCE: METROLOGIC BARCODE READER WAS WORKING NOW NOT WORKING
USB CABLE PLUG IS DAMAGED. HOW DO I REPLACE IT OR FIX IT. ITS VITAL TO OUR BAR CODES. CHARLES FRAZIER TEXAS FARM BUREAU 254-751-2580 THANKS
Posted on Apr 21, 2009
The scanner works fine but it doesn't automatically submit the info. Is there a setting somewhere that allows it to work this way?
scan "enable CR suffix" from your manual. You may also have to scan "enable LF suffix", but try it without first.
Oct 12, 2012 | Metrologic Instruments MS7120 ORBIT...
My metrologic orbit scanner ms7120 wont register with cash resgiter
I think you've answered your own question. Spilling water on any electrical equipment will inevitable cause failures. It requires a repair, which we can do for you.
If you require an help on this scanner please dont hesitate to contact us
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 09, 2012 | Microsoft Metrologic MS7120 ORBIT Barcode...
Ms 7120 barcode scanner does not scan some barcodes
i have 4 Digit Barcode From my Software i Printed it not reading the Font Name is (C39Hrp24DhTt)
Sep 30, 2011 | Microsoft Metrologic MS7120 ORBIT Barcode...
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
SCANER BEEPING
hello,
I have a same issue with my MS-7120, how ever mine is in worse stage, when i power up, it beeps and u can see green/red light blinks on top, and it tries to spin the inner motor + tries to turn inner light on, but after several seconds it goes dead. how ever red/green light blinks on top.
i contact the company which i purchased from, he told me these scanner has life expectation of approx 3 years, after 3 yrs they die.
i was told cause is from heavy/light voltage transfer from outlet.
and they have to be repaired by orbit support.
i am afraid to tell your, sounds like urs is ready to die. just beware !!
i hope this information helps you.
Jun 23, 2007 | Metrologic Instruments MS7120 ORBIT...
Metrologic Instruments MS7120 ORBIT Barcode Scanner Logo
79 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
