Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
Connecting the power swtch cables and others
I need to connect the usb1, usb2, hdd led, power reset switch, mic l, mic right,
    Scholar:
  • 84 Answers
I understand from this post that you need to connect the mobo to your casing/chassis.
There is a detailed diagram that can be found on the owner's manual that ships with your board. In case you do not have this, you can find one from this site:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope this helps.
Posted on Jun 27, 2009
Idnt knw hw to cnnct power switch , hdd led ,speaker , reset.led+ , led- . pls help me by sorting out my problem.by full description . and photos of connecting cables.
The front wires are usually for power, hdd led. power button and reset button and sometimes extra usb ports and audio ports. All motherboards have a small section that has 8 to 10 grouped pins protruding that you can attach these wires to. The motherboard will diagrahm where the pins hsould go. For example the light for the hard drive wires are probably labeled "HDDLED" and there is two of them. One positive charge and and ground. On the motherboard, in the grouped pins there is a small label that goes:
''___'
'_____'
HDDLED
PWLED
It may look like this but in a different arrangement. What does this mean? Connect HDDLED to the top two pins. Doesn't matter which way the positive and ground go. And connect the power led PWLED to the bottom pins. Follow this for all the other labels.
Jul 05, 2011 | Computers & Internet
MSI K8MM-V - Usb on the front case work like usb1 and not usb2.
May be problem on front USB port in CPU.Connection are very loose,so ti can detect.
Change or replace cassing.
Feb 08, 2010 | MSI K8MM-V Motherboard
I lost all conection from mother board (USB2 and
there is a label on the mothereboard on what connector you will put..youll see hdd,pwr something like that
Dec 13, 2009 | Foxconn 865G7MF-SH Motherboard
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
External Drive won't power on
Actually the simpletech dosent need power adapters so u dont need to check for adapters and if you are connecting to usb2 port the power should be embaded so just connect the single usb cable not the both if using usb 1 then connect the both usb cable to usb port if u have already done this please try to change the usb cables wich is connecting the hdd and the pc something wrog in the cable for sure
thanks
Jun 01, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Compaq 252608-001 motherboard
hello sosumo,
see carefully on the board there might be some sign like:
  • HDD-LED
  • PWR SWTCH
  • SPKR
  • RSET
  • PWR LED
These are the points on your board where you have to connect frontpanel connections.
For more details goto HP website and search manual for your product using your board's model no.
Thanks
Iqbal
Apr 21, 2008 | Compaq (253219-002) Motherboard
Need to connect Mercury PVM900M motherboard cables
my name is Allan kaitila from Tanzania
I bought a motherboard Mercury PVM900M,but i dont know how to conect it.
So may I have its Diagram that shows
The following wires and send it to me through allanafricanboy@yahoo.com
1. SYS_FAN
2. CPU_FAN
3. ATX_12V1
4. POWER SW
5. RESET SW
6. H.D.D LED
7. POWER LED
8 MIC
9. L-RET
10. L-OUT
11. R-RET
12. R-OUT
13. G
14. USB1
15. G
16. USB2
17. G
18. SPEAKER
Feb 25, 2008 | Mercury P4VM800M7 Motherboard
Power switch
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
+PLED -PLED +PSW -PSW NC NC NC NC
+HDD -HDD -RST +RST +SPK NC NC -SPK
Key:
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
VCC -DATA +DATA GND NC (USB1)
VCC -DATA +DATA GND NC (USB2)
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Dec 11, 2007 | Abit nForce2 NF7-S2 Motherboard
FREEAGENT 250 GB AND USB2 NOT CONNECTING
Most of the time if you get an event 51 error you will need to reinstall drivers associated with that device to fix it. I would delete the device from device manager, uninstall any software that you installed for it, then restart your computer and reinstall the software. I would do this for both the card and the drive. I would also run Windows update to see if it finds any other drivers that you do not have installed. If that does not work it is possible that the card and drive might not work properly together. The only other thing I can suggest trying is reinstalling windows
Nov 14, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
126 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
