Question about Troy Bilt Tb70ss Gas Trimmer
Weed eater runns great while at idle but not under trottle
Troybuilt less than 2 years old i think model is tb-90.The unit runs great while at idle but when you give it the trottle to operate it want stay running ???
How do you remove the cutter head from a troybuilt TB539E string trimmer
Posted on Aug 06, 2009
    Problem Solver:
  • 7 Answers
When is the last time you changed the air filter?
Posted on Jun 26, 2009
How to fix my Weed Eater MAX TE475Y TWIST 'NEDGE that wont start
First diagnose whether its a fuel, ignition, or compression problem. Remove the air filter cover and air filter. Spray a shot of carb cleaner into the carb and attempt to start ( choke should be open, throttle closed). If the unit starts on the prime then you have a fuel problem. Proceed by rebuilding the carb and if the fuel lines or primer bulb are brittle or discolored then replace them as well. Be sure that you use fresh fuel ( less than 2 weeks old) and if ethanol is in your fuel be sure there is no water in your fuel. If the unit doesn't start on the prime then check spark and compression. Compression should be between 120 and 140. If less than 90 the unit should be replaced.
Aug 24, 2014 | Garden
Troybuilt tb80ec wont start
If you didn't over winter the engine properly it could be several things. Start with replacing the fuel filter. If it still won't start... time to put in a carburator kit. Next time make sure you run your weed eater dry and spray some wd-40 or the like into the spark plug hole.
Jun 02, 2014 | Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas...
Km 90 r runs then shuts off
have you tried checking the fuel line
Jun 30, 2012 | Cars & Trucks
My two year old featherlite weed eater head stops spinning while I am using it. I started a few months ago and would happen randomly halfway through weed eating my yard sometimes, and then it kept doing...
It could be the spool connection or maybe a bad spline engagement, anyhow go to( jacks small engines.com ) and scroll down to your machine under Poulan/weedeater and look up your model they have just about every model you can think of. There you can see the make up of your particular unit and try to resolve your problem.Good Luck...
Aug 16, 2011 | Garden
I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
May 16, 2010 | Garden
Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
Mar 13, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
Carburetor adjustment weed eater fl sst 25,will only run if held 90% to the right.
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
Apr 22, 2009 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
957 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
