Question about LG Side by Side Refrigerator w/ LCD TV and WeatherPlus Information Center - LSC27990
The ice does not drop out when holding a glass under the pour spout. Ice maker is fine
  • 909 Answers
Sounds like the F.F. is not leveled correctly. If it's making ice but not dropping it and you are certain the mechanism is working, then it may be leaning back too much.Try winding the front feet to reset the level.( A friend had a similar problem when the back foot sunk into flooring)
Posted on Jun 26, 2009
No ice
If ice is formed but will not drop just pour hot water over the cubes. Or the teeth that push out the ice are getting stuck, in that case hold down the on switch to advance the teeth manually.
Apr 27, 2013 | Freezers
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
My ice maker doesn't make ice but i have water in the door
Your machine has a dual water valve. The ice maker side coil is dead most likely. You can confirm this by loading your ice maker with a glass of water. If it chunks out a batch but fails to make anymore then that is a sure sign of a bad water valve solenoid.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 08, 2009 | Refrigerators
Do i have it hooked up correctly
If you have the line connected to the rear of frig. and the valve is on with no leaks you do have it hooked up properly. The water has to go through a series of solenoids and about forty or fifty feet of tubing before it reaches the door. This process takes a bit.Hold a glass under the water fill spout and press it in. If you can hear the sound then all you need to do now is wait. continue to hold the button until water comes out. dispose of the first few glasses of water and the first few drops of ice. this will allow the system to be flushed of all contaminants. Note that when an ice maker is new or not used much it will not make very fast. it usually takes about 24 hours to make the first drop. Hope this helps and good luck.
Feb 26, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker isn't getting water. Water works on door, and line from ice maker has water in it, just not all the way to the ice maker
Icemaker is probably bad. If ice is in mold it is bad. If not, pour some water in it and see if it drops cubes after a few hours. If it does then fill spout to i/m must be frozen up- thaw it out. Common for i/m to go bad. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag MSD2756G Side by Side Refrigerator
LG Side by Side Refrigerator w/ LCD TV and WeatherPlus Information Center - LSC27990 Logo
82 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
