Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Kitchen aid microwave oven not working.
My microwave oven will not stop beeping.. I get an F2 on the touch pad, I can not set the clock, and when I try to warm up food sometimes the food will not warm up.
  • 9 more comments
  • DavidKid Nov 06, 2007
    In order to have peace and quiet I have to unplug the microwave oven.If you can help please write back, Thanks.
  • Anonymous May 20, 2008
    Exactly the same problem. My microwave continues to beep and displays an F 2 error message. What should I do? Thank you!
  • Anonymous Nov 16, 2008
    The microwave beeps on its own then locks itself. Sometimes the F2 message is displayed. It's not frequent, but started this about a month ago.
  • roseoneal63 Nov 19, 2008
    I have the same problem - will look at the pad - just started today - I know I cleaned last nite with spray right on the pad - who knew - Lesson Learned.
    This is a great site!! Thanks!
  • mellocello20 Nov 26, 2008
    I have the exact same problem - Fault #2. I believe it's the control panel that's malfunctioning. I had to resort to unplugging the microwave also.
  • Anonymous Dec 06, 2008
    Our Kitchen Aid oven touch pad will intermitantly (two or three times a year) malfunction by going into LOCK MODE, become inoperable and BEEP.It will not unlock using the manuals instuction guide by pressing and holding the 0 pad for three seconds.If the 0 key pad is depressed for 20 or 30 seconds it will LOCK ALL key pad functions and flash a E-2 message. The only way to get it operable again is to unplug it for a few hours (overnight) and it will function again. I am now awaiting service from my exteneded warranty policy provider in hopes they will replace the complete touch pad assembley.Always assumed that Kitchen Aid was a superior product but that mith has been shattered.
    J. S.
  • Anonymous May 15, 2009
    same problem... mine turns on like its cooking something. It started out that we could unplug it and it was okay for a few days... now nothing fixes it.
  • rehaklaw May 25, 2009
    Just happened to us. Installed 1/23/06... woke up to beeping and and F-2 displayed. Locks keypad on its own then after 15 minutes unlocks by itself ???
  • Anonymous Mar 13, 2014
    sharp microwave ovens start and stop switch is not working . number is working normally.if somehow take start the oven work normally ie warm food. now what to do?
  • Anonymous Mar 20, 2014
    touch pad doesn't work
    Husband checked circuit breaker and reset it but microwave still has no power.
  • KitchenAid Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 473 Answers
Kitchen Aid Built-In Microwave Oven Fault Codes Failure Code Fault Code Description Solution F1 - E3
F1 - E4 Electronic control malfunction Replace control. F2 - E0
F2 - E1 Keypad not connected Check keypad connector for firm connection. F2 - E3 Keypad held down too long, or keypad is shorted. Press CANCEL, if error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch).
Posted on Nov 06, 2007
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
Accidently locked microwave model#ME18H7045FS can't unlock HELP
try this. In future, the make helps :>) Also it is 'SF' not 5F. ME18H704SF
To Set:
Touch and hold the CANCEL/OFF Pad for
three seconds. The Display shows "LOCKED"
and the oven beeps.
To Cancel:
three seconds. "LOCKED" disappears from the
Display and the oven beeps.
Read more:
Here is your manual
Samsung ME18H704SF User Manual Setting The Time Child Lock Options Kitchen...
Here is the full details on you microwave from Samsung
OTR Microwave with Ceramic Interior ME18H704SF Owner Information Support...
Jun 22, 2017 | Microwave Ovens
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ... > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy -
Read more:
May 28, 2015 | Microwave Ovens
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
Sep 10, 2013 | Microwave Ovens
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
If you don't have time to download, here's what the instructions state:
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
F2 E0 "Stuck key" ????????????
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^
Jan 03, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
3,616 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
