Question about Nintendo Wii Console
Wii remote will not turn on and the blue lights either
Wii remote will not turn on and the blue lights don't flash either even with fresh batteries
All you have to do is open the place where you put an sd card on your wii then open the battery cover on the wii remote and press the SYNC buttons at the same time and it WILL TURN ON trust me it works
Posted on Jun 26, 2009
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
The Wii Remote for the second player does not work. Once in awhile the blue lights flash. We have tried to follow the instructions for synchonizing the remote with the console. And we have put in fresh...
Our grandson emailed the solution.
Turn on the Wii and open the game menu.
Click on the Home button.
Click on the Wii remote settings at the bottom of the screen.
Press "Reconnect" and then hold 1 and 2 on both remotes.
We will have to follow these steps every time we want to use the Wii.
It seems like a 'bother', but it works. At least so far.
Dec 30, 2009 | Nintendo Wii Remote Controller
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
My Wii Remote Won't turn on!
1) Make sure there are good batteries in it.
2) Make sure that the batteries are in it correctly.
Otherwise, there should be no reason to get no blue light - even not being sync'd properly wouldn't result in no light. May have to fess up to Mom. :X
May 07, 2009 | Nintendo Wii Remote Controller
Wii Problem, the remote
make sure a combination of the 4 blue lights at the bottom of the remote are on (but not flashing, mind you). if they're not, this means that your wii remote isn't connected to your nintendo wii system yet. if when you press a button and none of the lights turn on at all, this means that there are no batteries in your wii remote. if it flashes, this means its trying to connect to your wii system. you might have to troubleshoot this a little bit. try to aim it at the bar that recognizes the wii signal (a separate piece that comes with the wii system).
hope this helps ;-)
Apr 04, 2009 | Nintendo DS Lite
Rockband special edition for wii....guitar lights and usb light is flashing
Make sure that the Guitar Wireless receiver, microphone, and drums are connected to the USB hub provided with Special Edition. Ensure that the foot pedal is connected to the drum set. Then, perform the following:
1) Ensure you have fresh batteries in the Wireless Guitar
2) Insert receiver into USB hub
3) Turn on Guitar via switch on back.
4) If both the guitar and the USB receiver is flashing blue, then press the guitar logo button until flashing blue light on the receiver stops flashing.
Jan 19, 2009 | Nintendo Rock Band for Wii
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
WII REMOTE WILL NOT CONNECT TO THE CONSOLE
Make sure the batteries are fresh, and then open the battery compartment. There is a little red button. On the front of the Wii (turn it on), open the door where the SD memory card goes in. There is another red button. Press them both at the same time. The blue lights will flash on the remote, and it should then work.
Repeat for each controller.
Jul 09, 2008 | Nintendo Video Game Consoles & Games
Nintendo Wii Console Logo
489 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
