ERROR CODE ''SE''
This washer was working perfectly with no symptoms of trouble. Next load started to fill, drum spun intermitently, then shut down with error code SE. Is this something I can fix? The Washing Machine is an LG model # WD-1274FHB? Thanks in advance for your asistance.
Chris.
  • 111 Answers
Sensor error The connector (5-pin, male, white) in the wire harness is not connected to the connector (5-pin, female) of hall sensor in the MOTOR. ' Reconnect or repair the contact in the connector.
Posted on Jun 26, 2009
Frigidaire washing machine model ATF6700FS2. Had it in to a repair place to replace the bellows. The bellows in not centered. I don't know if that would impact this problem. I try to start the machine...
Hello Kerri, thank you for your inquiry!
First, if the bellows is not centered it is highly recommended to get that repair. If you are getting an error code E23, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards!
Sep 23, 2013 | Frigidaire GLTF2940ES Front Load Washer
EWX14450 washer dryer. Drain works fine. Why is it overflowing?
Found the problem with mine that had identical symptoms... after taking the lid off. i took the pressure switch off the hose. blew on the pressure switch when filling and you can hear the 3 clicks. the machine resumed onto next phase. i blew down the hose and this was clear and bubbling into machine. but then i discovered half way down the hose - it was damaged and had a hole. presumably from the drum rubbing on the hose over many years. now just need too replace this and it should work fine.
Apr 29, 2013 | Electrolux Washing Machines
LE code is flashing when I try to run the machine
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 25, 2010 | LG WM2277H Front Load Washer
Washer fills and drains, but the drum does not run
Joe, Thanks for the prompt reply. OK, it sounds like one of two possible culprits, 1) the belt has broke or spun off. 2) the brushes in the motor are worn...although the initial symptom of this is typically manifest in "no spin" so I'd lean towards a broken or spun off belt. You'll need to remove the rear panel for a visual inspection to confirm or dismiss either possibilities. Let me know what you find out. If the belt is off check for possible reasons "why" ? It can be a loose drive pulley, ( the large one, not the motor pulley ) or simply an unbalanced load on the previous wash, just a heads up since you're looking around in there anyway. Of course the belt itself may be worn ( stretched ) or broke and thus at fault as well. Good luck, I'll watch your post. macmarkus :)
May 04, 2010 | Bosch WFK 2401
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Fault code 5E
possible pump problem
try cleaning out the filter
Nov 01, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
670 people viewed this question
Top Washing Machines Experts
