We had this problem almost 4 yrs ago. It was the damper assembly which is a common problem w/ GEs. A damper is a door flap that opens and closes between the fridge and freezer that allows cold air into the fridge to regulate the temperature. Eventually, it breaks, allowing in too much cold air into the fridge, thus making both sides a freezer! Fixya's link that helped me is this one, which is very helpful: http://fixitnow.com/wp/2007/12/06/ge-side-by-side-refrigerator-freezing-the-beer/. You also might need to enter a diagnostic code when you replace it. Check this out also:
http://fixitnow.com/wp/2009/10/02/activating-self-diagnostic-mode-in-a-ge-arctica-refrigerator/. Don't let the description of the fridge as a GE Arctica mislead you. These are different models, but internally are the same components.
SOURCE: I have a side by
please check your door seal this the the number 1 cause of high humidity in refrigerators. make sure the door closes completely as well
SOURCE: some fruits and vegs freeze in drawers, but not all
GE fidge it is a common problem...air dampers stuck wide open..too much cold air going to fresh food side from the freezer..you need to call repair man
!!! but if you still want to do repair by yourself, send me model number i send you some ideas and most important some images...so you can put everything back together after you done :)))
[email protected]
SOURCE: frig won't hold set temp keeps freezing things.
Thermostat is defective.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Water is pooling under the veg/fruit drawers..cant
Your freezer goes through a defrost cycle and drains the melted ice ,somewhere the drain is clogged or iced up .Look for a little hole or hose coming into drain pan underneath and trace up.Might have to take back off.
