Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 46D62U incompatability
I bought the TV in April 2007 I have a cable box and DVD both hooked up to the HDMI and both worked great then one day watching TV the screen went blank and we got an error message on the screen stating "the auto output of the component is incompatable and to check it" the same for the DVD playerable . We hooked the cable box to the RGB cable and works fine. Not a cable issue has to do something with the HDMI ports
  • 53 Answers
Most likely a defective Main Board. I suggest calling Sharp 1-800-237-4277 to locate your local Sharp Authorized Service Center.
Posted on Mar 14, 2008
Hdmi not working
I don't know the particular system that you are using, but it could be a setting in "options" that is preventing you from using HDMI. It is also possible that your HDMI cable is broken or incompatible in some way.
Oct 28, 2013 | Sharp LC-32D47UA 32 in. LCD HDTV
My husband bought me your DVD Recorder Model No. DMR-EH75V for Christmas in 2006. It worked with my analog TV and a COMCAST cable box. In April 2007, I bought an Olevia HD TV and changed to a Verizon...
Due to certain limitations of the Panasonic DMR-EH75V, it can only accommodate composite Video INput and give composite Video OUTput as well as the standard Audio L/R. Additionally, if your Verizon FIOS HD cable box has an RF OUT, that can also be connected to the RF/CABLE IN of the Panasonic.
Please refer to the simplified diagram below.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Televison & Video
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hdmi input not working
Sounds like a failure on the main or av pwb in the TV. Do you have another component such as sat. rec or cable box to try with hdmi?
Jan 29, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
355 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
