Question about Cycling
I purchased a 16in boys Mongoose and took the training wheels off but the back tire seems to be rubbing and just Not spinning correctly..what might be the problem?
    Problem Solver:
  • 7 Answers
The wheel isn't centred correctly is my bet. Looking at the bike from behind, is the wheel pointing straight ahead, or is it off to one side? Common mistake to either not put it back in straight, or not tight enough, and the chain tension when you pedal will pull the wheel off centre.
Posted on Jul 01, 2009
How to install front tire of mongoose bmx
Remove wheels, remove valve stem from innertube. remove tire by getting tire edge over rim. reinstall in opposite direction. If this seems difficult consult local bike shop for assistance
Dec 28, 2012 | Freestyle Mongoose Bmx & Owners Manual -...
I am wondering where I can order a back wheel for the mongoose 20 inch outer limit boys bike. Accidently got run over and is very bent. Thank you deb
Any Mongoose dealer or bicycle shop should be able to handle that or just web search for a 20" BMX wheel. It doesn't appear to be unique.
Sep 13, 2011 | Mongoose Outer Limit Boys Bicycle Pad Set...
Hi....my problem is my kid cycle's pedal is so hard....he can't pedalling...so what i do for normal peddaling ?
Visually determine where the unavoidable resistance is originating. Does the rear wheel spin ok? Tire rubbing? Bearings frozen?
Aug 03, 2011 | Huffy Cars Lightning McQueen 12 Boys'...
My 5 year olds 16"
YOU need to assess if something is rubbing somewhere or the bearings are shot. Remounting the wheel correctly will solve the rubbing issue and probably eliminate a dangerous condition.
If the latterer, decide if repair or replacement is the better avenue. A bicycle shop could repair/relube the bearings faster and cheaper than locating a matching wheel.
Jun 28, 2011 | Mongoose 16 Girls Pizazz Bike
New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Dec 28, 2009 | Mongoose Cycling
Took the back tire off of a Mongoose Racer X 7808
I hope this helps:http://www.mongoose.com/usa/eng/bmx/MongooseTemplates/downloads/OwnersMan_Mass_010307.pdf
Aug 17, 2009 | Mongoose R1602 Jr. Racer 16" Boy's Bike in...
16" Girls Mongoose Pizazz Problem!!!
some bikes are like that. The rear wheel only spins with the pedals. Try pedaling backwards and see if the wheel goes back. If it does then that is normal.
Jul 13, 2009 | Mongoose Butterfly Summer 12" Girl's Bike
Back tire changing on mongoose gravity games bike. How do you change the back tire in this bike? It is very hard and confusing. I don't know how to do it. I need help.
If you have pegs on the back you will need a deep socket to fit the nut and a socket extender and a socket wrench. with the wheel off it is just the same as changing any other bike tire. Just make sure you check the inside of the tire carefully for anything poking through that may puncture your new tube. Also check to see if you need a new tire and make sure you inflate the repaired tire to the correct pressure or you may get a pinch flat.
May 11, 2009 | Mongoose Gravity Games BMX Bike
Cycling Logo
106 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
