Question about GE Refrigerators
Not cooling clicking sound behind circuit board
  • 4 more comments
  • huntercontj Jun 26, 2009
    yes we did have a power outage
    the display that adjust the temps are also out as i believe this model has 2 boards
    nick, as the displays are also out does this mean anything?
    the isplays are off and making no sound, the clicking is coming from behind the circuit board behind the fride about half way up, Mod #pds22mhrbcc and I got a quote for $140.00
    did you get that one nick?
    do you think I will need them both?
  • 351 Answers
You will probably have to change that circuit board, but i first want to know if the compressor is warm? did you have a power outage?
Posted on Jun 26, 2009
  • 2 more comments
  • Mark Nichols Jun 26, 2009
    it fried the board then, is the compressor hot, beware this board is very pricey i can get you a good deal with free shipping if you call whirlpoolpartssurplus.com mark
    yes but which one is clicking? can i get your model number?
    wr55x10656 main control inback is 130.00 and the temp control wr55x10340 is 80$$
    probably not i would buy the main control first and put it in... i cant really tell with out hooking a computer system up the whole thing....
How to replace main circuit board
The circuit board is normally located at the back of the appliance, behind the metal grid along the bottom, unplug the appliance, unscrew the grid and the PCB mount, disconnect the pcb and swap with new one, then reassemble
Apr 10, 2014 | LG LRSC26930TT 36" 25.5 Cu. Ft....
GE model PDS22MFSAWW, clicking as if the unit is turning on and off? The digit temperature lights are gone, but fridge is running okay?
Due to the digital temp lights no showing , this is a sign of the main control board bad . The clicking from behind the refrig , clarrifies this . Replaceing the main control board , behind the refrig , behind the small 8 " X 10 " panel , will solve both problems . The part # WR55X10942 .
Dec 14, 2009 | GE Refrigerators
Clicking sound on the circuit board behind fridge at part #11Z4H1 what do i do? Thank You
Replace the circuit board . A model number would have helped , to give you the correct part number .
Nov 28, 2009 | GE Refrigerators
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
Motherboard making a knocking sound
Most likely the motherboard is the problem, There are several relays on the board and you might hear them clicking. a defecrive board could cause the problem you describe.
Aug 14, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ticking sound from rear of fridge...
could be the water valve assy. I`ve never heard a circuit board click. but anythings possible.
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
D52W20 circuit board
The center circuit board is the green CRT drive circuit. that board could be bad or the green CRT could be faulty. I have access to both those parts for your model
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
