Question about Epson Stylus NX400 InkJet Printer
I replaced the black cartridge in my Epson nx400, computer said it was low, and now printer will not accept command to print. Why?
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Posted on Jun 29, 2009
Will the Epson stylus office bx635fwd print if only the black has ink in it ?
Since 2005 Epson and all other inkjet manufacturers use a little of the colors to print black. so ,no,you will not be able to print just clack.
Even color laser printers use the colors to print black.The exceptions since 2009 have been the Canon color lasers and the HP color lasers units they provide print engine for.
Mar 29, 2014 | Epson Stylus NX400 InkJet Printer
How to remove epsom NX400 print head
The print head on the NX400 printer is integrated into the ink cartridge and therefore when you remove the cartridge you are removing the print head. . . If you want to clean the print heads / nozzles then see the procedure in the NX400 User Guide in the section for Adjust Print Quality. . . .The User Guide can be found at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
My Epson NX400 will not print even after I replaced my black ink cartridge twice. Is it possible to fix ? Or, do I need to buy a new printer and what would it cost to repair? Or , how would I repair this...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 30, 2011 | Epson Stylus NX400 InkJet Printer
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
I've never change the ink cartridge before.
Usually you can find that the top of the printer can be lifted open. You will then see the three ink cartridges. remove each cartridge and see how low the ink level is if there's a centimeter or more it should not need changing. However some brands will force you to replace them all. or it won't accept that you have followed the directions.
Good luck,
Jim Hart
Jun 20, 2010 | Epson Stylus NX400 InkJet Printer
Hi-My Epson NX400 inkjet printer does not
Hi there
You can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 18, 2010 | Epson Stylus NX400 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
432 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
