Question about Samsung CLP 300 Laser Printer
My unit is about 1 year old. it has missing print areas. with only 2700 copies on it. i assume its the imaging unit?
    President:
  • Samsung Master
  • 1,447 Answers
Yes you change your printer drum unit
Posted on Jun 28, 2009
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
When copying by putting the original thru the machine, half the copy come out solid black. Putting it on the glass under the lid the copy comes out perfect. Any ideas why this is happening? How can I...
A user default
1.The printer is possibly not designed to perform in color copying through the machine feeder area, only on the photograhic image scan area. Discontinue scanning the image in feed area.
A Technical default
1. The device is nearly out of ink
2. The device printing bands are clogged requires cleaning
A printing material defect
1. The positioning of the medium to be photocopied only achieves success when layed flat on the screen. Possible images are likely when lightening does not escpe in the process.
Consider, using an alternative copy machine that would achieve success.
contact technical expert, soon as possible
Dec 01, 2010 | Canon LaserCLASS 510 Printer
Getting lines about 1-2 inches down the side have a image 2200 located in Wheeling Wv. area code 26003 can not find a local dealer listed to look at it
are the lines also on printed image or only on copy?
If only on copy - clean the copy glass.Eaven the smallest dirt on copy glass could give you the problem.
if on printed too, it could be drum unit.
For local dealer i cant help you, but if its drum unit you can change it on your own.
To check drum:
open front cover, realese left blu handle, realese the toner handle, unscrew grey screw ( screw is unscrewd by hand ) on drum unit, and pull it out.
If there is any lines on drum replace it.
The drum goes aprox. 60-70000 copies.
If the drum is ok, also check fixing film - for thath call/find service.
hope that helped
Jul 02, 2010 | Canon imageRUNNER C3200 Color Printer
Missing print areas with black ink
If it's a manufacturing defect, then surely Samsung is at fault and should rectify.
I would phone them back and if unsatisfactory, threaten them with court action, but don't get aggressive with them as this will go against you and in these current financial times Samsung can't afford the hastle.
Jun 27, 2009 | Samsung CLP 300 Laser Printer
Sharp AR168D won't copy
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
Mar 31, 2009 | Sharp AR-235 Copier
Brother MFC7820N
I assumed you are using a digital copier/printer, in digital machine there were 2 kinds of diagnosing a problem, and you are right with your observation Copying and Printing, and each have two separate troubleshooting.
If you say that in printing is fine, then the problem is with the scanning part which is in your Optical Unit, here's some pointers
1- Open the optical glass on the top, with screws
2- Observed the optical unit with 3 reflective glass, it could be dirty
3- the middle of the optical system is called the CCD which converts the image from the reflective mirrors, see if you can find dust and dirt.
4- Check the lamp for any sign of dirt this could cause also some problems.
these are the only areas you need to check, nothing else, and this would surely solve this problem
Jul 15, 2008 | Office Equipment & Supplies
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Laser Printer Problem
Do a panic stop while the machine is in the middle of processing copy. Remove the imaging unit and lift the drum cover to view the surface of the drum. If the image produced on the drum is OK (ie.no ghost image) then focus your attention on the hot rollers just before the paper exit. Otherwise your problem is the imaging unit.
Dec 31, 2007 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
78 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
