Question about Arrow Fastener Co. Lt Duty Staple Gun - JT21M
My jt 21m stapler is jammed and i cant get it to open
I have a arrow jt 21m stapler i don't know how to load the stapler could you help
    Sergeant:
  • 384 Answers
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Posted on Jun 26, 2009
How do I free up a jammed staple in an Arrow P22 model?
Hi Francis. Remove the staples from the Arrow P22. Place a piece of wood (rod) about a quarter of an inch thick between the arms of the stapler just behind where the stapler is ejected and press down a couple of times until the jammed staple is dislodged. If the plunger is already jammed in the downward position then first pull it up and then push it down again. This procedure has worked for me on a variety of staplers over a period of very many years. Good luck!!
Feb 04, 2015 | Arrow Plier-Type Stapler - P22
Load staples in et50 arrow stapler
It will probably have a release at the bottom rear of the stapler. Just push the release in and down to release the rod/spring assembly (the release catch may be silver in color). Drop in a stick of staples the reinsert the rod/spring and reengage the release.
Dec 12, 2014 | Arrow Tools & Hardware - Others
Arrow jt27 staple gun won't load or staple
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Jan 16, 2013 | Tools & Hardware - Others
Unable to load my Arrow Fastner Model JT-21. Can you help?
is there a problem with it? here is a manual that has pictures. If you have a jam or something, repost what the problem is.
Aug 09, 2011 | Arrow T50P ARROW STAPLE GUN
How do you load new staples?
Find the button on the bottom of the stapler's back edge. Push the button in and down. Pull out the bar that pushes the staples into place. Slide in a row of staples with the points facing down. Push the bar back and lock it into place
Feb 20, 2011 | Arrow CHROME STAPLE GUN ARROW IND....
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
I have an Arrow JT-21M staple gun. How do I open it to add more staples?
there is no loading trya that pops out. the pusher arm is removable. when that is taken out you slid in the staples and replace the pusher with the locking tooth facing up.
http://www0.epinions.com/prices/Arrow_Fastener_PK21_Parts_Kit_for_JT21M_And_JT21CM_Staple_Gun_Tackers
Sep 03, 2010 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Cant get staples into it!!!
Sue, First, confirm that you have the right size staples. They are sized in two dimensions - width and length. The most common width sizes are T50 and T35. Your stapler and your pack of staples should have a number such as this. Your stapler will accept staples only of the correct width but of various lengths. The lengths are given in fractional inches - 3/8 inch and 1/2 inch are common.
But perhaps your problem is how to open the stapler. It does not swing open like a stapler you would use for papers. Instead, it has a sort of spring piston that has to be removed from the back-end of the stapler. If you lay the stapler down flat on the table so that the hinge of the handle is at the upper left corner, then what I am calling the back-end of the stapler is the lower right corner. Pick up the stapler so that you are looked directly at this back-end. There is a small metal square at this corner that is spring-loaded and is held in place by a little hook. Push in on this metal square as you move it up (or is it down?) to disengage the hook. Now the piston will pull out easily. Put your staples in the hole (they will only go in one way) and replace the piston. I hope you found this helpful Good luck!
Aug 19, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
I don't know how to load staples into the Arrow T55 manual power stapler
there should be a spring loaded clip at the end of the stapler opposite from where the staples come out push it in to release
May 27, 2010 | Aerobie Arrow Fastener T55C All Chrome...
Directions for Arrow JT-21 staple gun
The jt 21 is that little red one, I have one in my shooting box, only takes the jt staples, and operates just like any staple gun. Feed it from the back.
Feb 20, 2010 | Hand Tools
Arrow Fastener Co. Lt Duty Staple Gun - JT21M Logo
2,204 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
