Question about E-Machines M2350 Notebook
TFT Screen Loose Connection?
Symptom: At one point the TFT screen would be on and functioning but if the screen is adjusted to another angle, it would go dark. Now it doesn't function at all. How do I access the "ribbon wiring" for the TFT screen to make sure it has a good connection?
  • mjgraft5 Nov 28, 2007
    Thanks for the insight above. I checked the cable and it wasn't pinched or moving around, so I ordered, received, and installed another LCD inverter board for this laptop from Now the laptop's monitor is very very faint. As though it was on a dimmer switch, very low.
    Any other suggestions from anyone?
  • 33 Answers
These models sometimes have a problem with flickering screens, screens going black, etc. This is caused by the cable running from your LCD lid area to your motherboard.
To gain access to this cable, flip your laptop upside-down, but make sure the back is facing you (vents and such). There are 4 screws along this side, you only need to take out the middle two.
Once that is done, flip your laptop upright again, open the lid and pry up the power bar. The cable you seek is running on the right side, should be wrapped in gray-colored tape.
Adjust this cable so that it cannot move and is not being pinched, and you should be set.
If that didn't work, and since your LCD is no longer lighting up at all, I'm almost leaning towards your problem being your inverter board. Very easy to swap out, and cheap at around $20 at
The LCD inverter board is located at the bottom front part of the LCD lid. Just take off the front frame of your lid by removing the power bar (as instructed above) and then removing the screws under the rubber bumpers on the LCD frame. Then it's just a matter of carefully peeling the glue holding the frame down at the bottom.
Your inverter board is the long green-colored board you should see with the front frame removed. This board will have two connections plugged into it. Quite the easy swap, yes?
Posted on Nov 16, 2007
  • Code
    Code Nov 28, 2007
    If it is very very faint, it sounds like that inverter you received is bad as well. That is sometimes possible with used equipment unfortunately.
    I bet if you contact where you purchased it from they will send you a replacement. Give that a try, I wish you luck once more! =)
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
I purchased my laptop in May of 2008 and the warranty has expired. I am having problems with the screen flickering. When it first started I could adjust the angle of the screen and it would work again for...
Most likely a broken wire in the wiring from the computer to the screen. Some place charge up to 100 dollars to fix it. This is a very common problem.
Jan 05, 2011 | Gateway M-6847 Notebook PC
The screen flickers on and off
no it maybe that the wires have come loose from your screen to the motherboard to solve this take apart your laptop and you will find one or two wires with a ring wer the screw is screwed on just titen them and check if anythink else is loose in the screen.
Best regards
Apr 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Laptop Screen Freezes and turns black When Adjusted angle.
It is possible that the video cable is chafing in the point where it passes through the hinge assembly. Try reseating the video cable, if that doesn't help, the replacing the LCD cable assembly is the likely fix.
Dec 05, 2009 | Dell XPS M1530 Notebook
Popping up of ''Auto adjusting'' on 15'' TFT BENQ monitor
Check the cable connections from the computer to the monitor, you might have a loose cable or bad connection.
Otherwise: did you upgrade your graphics driver lately ? And when do you get these popups, always or only when (i.e.) watching video ?
Aug 15, 2009 | BenQ Computers & Internet
How to adjust picture on projection TV
It should have in the menu ,under settings ,, convergenge,, it realines the colors,, ,,
Oct 03, 2008 | Philips 60P8341 60" Rear Projection...
My screen shows multi colors unless I physically hold the screen up in one place near the frame. I have to do a fair amount of adjusting to get it to stay so that I can see whats on the screen. I have a...
This is usually to to the graphics chip not being properly soldered to the circuit board - the chip is probably what is known as a ball-grid array and these are notorious for this problem.
If this is the case then you really cannot fix it and it will need a new mainboard.
If it is a loose connection to the screen then you may have a dodgy graphics cable which leads from the mainboard to the TFT display panel. Sometimes it may be that the connector on the mainboard is loose. If this is the case then it may be worth trying to take it apart (if out of warranty) and check that the multi-wire plug leading to the screen is firmly seated into the connector.
However, taking apart a notebook is quite tricky!
Aug 03, 2008 | Toshiba Computers & Internet
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Screen goes awire?
sounds like a backlight or display power problem.
Oct 24, 2007 | HP Pavilion ze2000 Notebook
Toshiba A-105 Satellite, LCD Screen problem
when you "adjust the angle of the screen", that can only be a faulty electrical connection. Try again at the mainboard connector.
Jun 04, 2007 | Toshiba Satellite A105-S4004 Notebook
E-Machines M2350 Notebook Logo
1,382 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
