Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Alert comes up that says yellow IU over life limit 30C-KM - is there any fix for this?
  • 32 Answers
What machine do you have?
si
Posted on Jul 03, 2009
Bizhub c350
Before replacing the IU select Utility - Meter count - Check details- Stop 00 Stop 01,enter 00000000 END,select Tech.Rep.Mode - Counter - Special parts counter-PC life.Press the Clear key to clear the counter value.Select IC life and clear the counter value.Turn OFF the copier and remove IU unit.After installing the new IU unit select Tehc.Rep.Mode -Function-F8 and press START.After 2 minutes the developer is initialized to make a copies. fcf3fced-96eb-4483-840f-8de548aa8045.jpg 378b39ea-2f19-4cf6-887c-617430da4931.jpg
Jul 14, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
How to switch off 150000 km service alert in Caprice 2006
You need a scaner to do this. Do not use a code reader it will not work.
Jan 23, 2014 | Chevrolet Caprice Cars & Trucks
Hi my nsme is tim nd gets trercorded vandevoorde
What model number is the one your talking about and this time in English okay? Thanks
Sep 10, 2017 | Televison & Video
Konica minolta bizhub c450 error code c-2555
Yellow Imaging Unit Failure.
Take out IU-Y, shake it, check the toner layer, Re install it.
and see if improvement, else remove IU-Yellow
May 06, 2013 | Konica Minolta bizhub C450P Laser Printer
Dear All, My Name : TSN Prasad My Bike : Hero Honda Glamour 2011 KM Covered : 1250, First Service Done at 540 KM My Problem : heavy White smoke arrives only when engine is Cool Sir, my bike exhaust heavy...
Hi, TSNP your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by worn out valve seals or a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.xbhp.com/talkies/help-me/32061-hero-glamour-white-smoke-exhaust.html
https://www.quora.com/White-smoke-is-coming-from-exhaust-2009-glamour-bike-12000-km-run-less-used
Hero Honda Glamour 2007 service manual DOWNLOAD FREE FULLMANUALS COM
Hero Motocorp Glamour 125 Disc User Manual
http://www.partsfish.com/page/oem-parts-for-honda
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 07, 2017 | 2006 Hero Honda Glamour PGM-FI
What does it mean when the display on instrument cluster says a little 1 and then a circled KM/h?
This is a vehicle speed alert nr.1 (in km/h). You can modify the speed alert also.
Mar 19, 2010 | 1997 Audi A4
Yellow iu over life limit - call for service 30C-KM Is this something I can fix or do I really have to have service come in?
The imaging units have a chip inside.
This one counts the number of copys/prints made with the unit.
Once the chip has reached his number, he gives a signal to the machine that it needs to be replaced.
There are ways to reset this chip with a resetter (kosts alot and is only good when you use a whole lot of units.....)
I think its better to order a unit and to replace it yourself, so you dont have to pay the technician costs.
greetz,
Marc
Jun 26, 2009 | Konica Minolta DiALTA CF910 Copier
Minolta copier ep2152
If you are asking about a ep2152. That is a very old copier, they may not make part for it. Let's try, do you have what looks like a front view of a camera lite up orange or flashing? If so, you need a new IU unit/ drum & cln blade & developer most likely sold sepperate. I don't think they make the whole unit as one piece. I could be wrong. Try making a copy with the IU unit out. If the marks are on the blank page that comes out, it is in the fixing unit.You will need to replace the upper fixing roller & lower roller & cln roller. If you put the IU unit back in and the line is there then you have to rebiuld the IU unit. Good Luck....
Oct 17, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
646 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
