Question about Maytag MSD2756GES Side by Side Refrigerator
Freezer and frig not cooling
The fan runs but neither side is cooling. Its not dirty underneath and I need to know why a frig only 4-5 years old would do this?
  • 351 Answers
Did this happen all of a sudden?
Posted on Jun 26, 2009
I have a ge GSH25JFXB WW side by side frig that was hit by a power surge. now, it does not cool like it use to. both the freezer and frig and warmer than before even when you turn it on full blast. they...
Start by checking the compressor. If it is running,you should tell by it being warm and a slight vibration/hum....it will start and should run until thermostat stops it. Since it's not cooling, it should be running all the time. There are 2 copper or stainless tubes entering the compressor. One should be hot;the other cold. If both are same temp,or the compressor not running,or is hot to the touch, your compressor is done for(some have a removable connector with contacts that are replaceable) Compressors aren't cheap.
Nov 04, 2013 | GE Profile PSW26P Stainless Steel Side by...
Freezer only getting 48' and frig side is only at 49 degrees
take the back panel off and see if the fan is running and if not see if it has power to it if it does replace the fan and see if ur problem is solved the coil underneath the fan should not be frozen even if the fan is gone out this could be a sign that the lil black element that runs through the coil is gone out now if all this is good and still same problem ur probably gonna have a freon issue and unless u know how to charge one i advise u call a tech and if its only 6 years old yes it worth trying to fix
Mar 01, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
GE side by side not cooling properly/outside surface hot
please check the condenser fan motor. it is probably not running or the condenser is very dirty.
remove the rear cover and it will show you the compressor and the condenser fan.
if the fan is not running, try to rotate it manually and feel if it is sticking .
if it is, it may just need the old wd 40 lubricant.
tnx 4 using fixya,
drcool
Sep 07, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Freezer on bottom cold but frig is warm
Just additional clues..(general). The defrost timers (on non-electronic) usually located at the bottom (underneath), have a tendency to fail. (One of mine is in the center, one was on the left side) There are usually about 5 wires connected to it. If it fails while defrosting.. the fridge will warm quickly and stop cooling, if it fails in cooling mode, you will have the icing up problem. (other) A squealing noise is usually a fan motor. -also- (Freon issues)..as freon is lost from a small leak, first the freezer will actually get colder, but the refrigerator section may be too warm (I know it sound stupid). When enough is lost the compressor will get hot and the fridge will not cool.
Jan 02, 2008 | Amana ARB8057CSL Bottom Freezer...
Maytag MSD2756GES Side by Side Refrigerator Logo
230 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
