Question about Sharp AL-1551CS Printer
Al-1551cs / L!
The code L1 keeps flashing & nothing works?
  • briscoflat Mar 20, 2009
    AL 1641cs
    I am getting the same error code, flashing L 1 , and unable to print.
  • 1,006 Answers
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Posted on Nov 07, 2007
My sharp AL 1551 CS is getting a L1 error code before that it was getting a E7 code. The scanner will light up and shut right back down, then it shuts itself down again.
I have a tip posted here on Fixya that will help you diagnose and repair an L1 failure code on the Sharp AL series copier.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If this works for you then please return here and give me positive feedback.
Thanks for using Fixya today.
Jul 13, 2010 | Sharp AL-1551CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
Sharp AL 1551cs reading L
I also have an AL-1551CS copier...normally the "L" has something to do with the scanner lock device underneath the left side of the top part (ie; the scanner) It's clear colored and round with protrusion to turn it from locked to unlocked...this is for moving the copier so the scanner (lamp and mirror assm) won't be disturbed. Use a flashlight or such to inspect the position of said device (ie; locked or unlocked) insure it is unlocked.....power back on and tell me if there is a number following the "L" Tim
Jul 03, 2009 | Sharp Office Equipment & Supplies
My al-1551cs sharp printer displays L1 and nothing works
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Jun 09, 2009 | Sharp AL-1551CS Printer
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
H 4 error
If the Reset does not work, then you have a fuser error and your machine will need service.
H4 is a fuser heating error code.
Meaning the machine is not warming up because of a bad lamp, thermal fuse, thermostat, and or thermister.
Hope this helps.
Good luck.
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Sharp AL-1551CS Printer Logo
437 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
