Need an cable for one of my seperates.
I have an a hatachi stereo that i have lost the cable to one of the seperates that joins them together to make it work. where could i purchase one from.
  • 909 Answers
E-bay, richersounds, most hifi/electrical shops.
Posted on Jun 26, 2009
Nissan 1995 n15 stereo wiring problem sony head unit
the way it sounds is you have your constin power wire wired wrong. Now i could be wrong but i had the same prob a while back.
Jan 03, 2014 | Nissan Cars & Trucks
JVC UX-EP25 ipod cable missing
Try www.jvc.com contact customer support and the technical department. I would first try www.ebay.com type make and model of mini stereo and scroll through the list.
Jun 06, 2012 | JVC UX-EP25 Shelf System
I have 4 wires, red (power(, black (ground), green (speaker), gray speaker...the stereo has these same color wires...so I connect the corresponding color. The boat has NO yellow battery wire that is on the...
(http://inform3.kenwoodusa.com/manuals%5CKTSMP400MR.pdf )
Here's a link to manual and wiring on page 30 on the PDF file.
Yellow is constant power from battery, for memory etc. Red should be to switched source.If need be, you can connect both to battery, but remember, you'll have constant power draw on battery when stereo left on but switch turned off, and will draw battery down, if you forget to shut it off, and leave the boat. Speaker negatives to black should work but I would advise hooking my 2 right and 2 left + speaker wires from stereo together, then to one of the speaker positives,right or left for better sound. Fronts will usually supply higher ( high and mid range), and rears will supply lower sounds (woofer) Joining them together will give better sound usually, when only using 2 speakers, on a 4 speaker stereo. You may want to test with them joined and not, to see what sound you like better.
Sep 26, 2010 | Kenwood KTS-300MR CD Receiver
Mp3
The problem is that a CD has a stereo signal and the Marshall is mono.
You could make a simple mixer cable with resistors as a completed cable is not something you will find easily.
Take three 1K resistors joined at one end and connect the open ends of those one each to the three terminals of a stereo plug that fits you CD player.
Connect a mono plug and cable with "hot" to the joined connection of those resistors. Connect the ground shield of that cable to the barrel connection of the stereo plug that one of the resistros is also connected.
NOTE: if you use the "line" output of the CD player, then use 10K ohm resistors instead of 1K.
May 06, 2010 | Marshall 15 Watt Guitar Amp
How to wire up 2 amps and two subs
Usually dont use 2 amps for 2 subs you can run 1 amp and two subs which is more common. But what i need to know is which cables if you are talking power cables or rca cables. If Rca then then go ahead wire together. Power is a different story and I need to know what you are pushing
Apr 08, 2010 | Car Audio & Video
Cd and radio play white noise
this is caused by static electricity running thru the earth cables of the speakers, try disconnecting the earth cables at the back of the stereo unit, and joining them all together, and re-earth them on the bodywork of the vehicle
Sep 11, 2009 | Kicker IX402 Car Audio Amplifier
Can I swap out the cd player for an mp player in the volkswagon transporter van
cant see it being a problem, if there is two head units together why not get a double din stereo?
Oct 28, 2008 | 1992 Volkswagen Golf
I have a 2000 chrysler sebring limited edition
what you have and are attempting to do is seperate the A/C condensor from the radiator. They are most usually bolted together. You need to keep looking to find where they have been joined, sometimes the bolt will almost be hidden.
jetski
Oct 04, 2008 | 2000 Chrysler Sebring
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
22 people viewed this question
 Grubhead
Grubhead
