Question about Husqvarna Forest & Garden 125bt Backpack Blower
My 125 bt blower does not reach full power sometimes (intermentent) I changed the plug and the air filter and still the problem persists, it's only 9 month old
  • 59 Answers
You can try turning the high screw out just a little if that does not work try turning it in some
Posted on Jun 27, 2009
My 150 BT hysqvarna blower starts and runs good at first and loses power and stalls after running for a few minutes.changed diaphrams and fuel filter and now does same but doesn't stall
Most people blow air through the carb passages without running something through them to remove the gelled fuel, also these small carbs use Welch plugs that limit access to cleaning carb completely. To do a complete job of it it must be fully dismantled (not air blown through passages) to make it operate correctly again.
Feb 13, 2018 | Cars & Trucks
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
How to change primer bulb on Husqvarna 125 b leaf blower
Remove air filter cover,remove air filter, remove two nuts holding the assembly,pull primer bulb assembly out,remove primer tube. Reinstall in reverse order. http://www.ebay.com/itm/530047721-POULAN-WEEDEATER-RED-SNAP-PRIMER-BULB-/190568099240?pt=LH_DefaultDomain_0&hash=item2c5ebe6da8#ht_1848wt_718
Aug 31, 2011 | Husqvarna Hand Held Blower 125 B Grass...
My DT 125 sputters terribly in midrange rpms. Funny though, when it is about to run out of gas (right before switching to reserve) the power smooths. Wish it could run like that all the time. I know two...
There are three things that could be causing the problems you mention.
(1) You could have a bad four hole washer in your fuel petcock that is causing fuel flow issues. Rebuild or replace the petcock.
(2)You could be have issues with a sticking float needle or an incorrect float level (or sunk float). Clean the carburetor , check the needle for wear, check the float level measurement, see if the float sinks or floats in gas.
(3)You could have a bad gas cap (gas cap vent) that does not allow enough air into the tank fast enough when it is full. Replace the gas cap or unplug the vent in the cap.
Dec 12, 2010 | 2004 Yamaha DT 125 R
Blower not running at high rpm when full throttle. Cleaned air filter, gas vent, gas filter and spark plug. Blower is 3 years old. Have not bought any new replacement parts.
Try removing the muffler and look inside of the exaust port, you should be able to see the piston in the full opening of the port. If you can, try starting and running at wide open throttle. If it runs fine( a bit loud, so wear hering protection), then you have a plugged or partialy blocked muffler or spark arestor. Sometimes rich mixture can cause excessive carbon build up.
Hope this was helpfull.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 07, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
2006 KTM 125 sx high revving out problem
Look into your power valve. If it doesn't operate freely, you won't get peak performance. They can get gummed up.
Jul 27, 2009 | 2006 KTM 125 SX
PoulonPro Leaf Blower will not run properly
the carb has a screen in it it needs to be cleaned out the fuel gets crystalized in the carb when it sits for a while. and if the carb has a high and low on the carb meaning 2 screws on the side of the carb .one is for air and the other is for fuel try this first start it up and give it full throttle and turn the high adjustment till it does something screw it in slowley and or out till it is at full rpm sometimes the adjustment screws do vibrate there way out of adjustment .if it dont work then take the carb apart to clean out the screen
Nov 13, 2008 | Garden
Husqvarna Forest & Garden 125bt Backpack Blower Logo
441 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
