Question about Pyle PLCD78M Car CD/ MP3 Player
Cant figure out how to install radio
The many wires in my car don't match up to the three wires on my new radio
  • charity_june Jun 26, 2009
    I have a 1999 saturn sl2
  • yadayada
    yadayada May 11, 2010
    of course they don't match up the player is DIN, what year and model of car
Put power mirrors 0n 1967 chevy c/10 problem with wiring
Get yourself a test light and figure out what harness wire does what when the switch is activated. Then figure out what wires control which movement to the mirror and match them up.
Dec 22, 2016 | Ford Cars & Trucks
My radio will my come on
I wouldnt go to the shop, if you need hands on help, go to an audio installation shop. You might also consider getting online and consulting crutchfield.com. The easiest install is to make sure you have the right wiring harness adapter to match your new radio to the model vehicle your doing the install. This will make sure your wiring is all correct. The wiring for the speakers, if not using the harness, is usually best to just run the wire straight to the speaker. Bypass the whole stock wiring. Especially if your using your own amplifier.
Oct 27, 2013 | Dodge Charger Cars & Trucks
Radio does not work/fuse is good/ no light, clock, sound, power etc
Question: Did you use a wiring harness to install the radio? If not, I recommend you get one and use it. You run the risk of frying you entire electrical system if you don't. Of course, you may get lucky, but not usually. The wires on the wiring harness will match the wiring of the radio you are installing. All radio wires are standardized in color. If you did use a harness, check the crimps on the wires. Hope this helps
Aug 22, 2011 | Car Audio & Video
I just bought a new kw-AVX740 radio and i have a 01 mustang and i don't really no how to install it
first and foremost you need to buy a car audio installation kit for your car model and year. Wal mart has some, but i think you may need to drive down to your local car audio shop and buy one from them if wal mart don't have them. Remove the old/factory radio. If an aftermarket radio is already installed then you may get lucky and find the harness already installed, but depending on what kind or radio it is( ex: DIN or Double DIN), but the specs for your radio is Double DIN(fat) so you may still need to buy the installation kit. Once you have the kit, everything is color coded, just match the wires and connect, then plug the harness after you have secured the wires. For a clean professional installation look, solder your wires(60/40 solder and soldering iron needed) and seal the connection with a heat shrink tube(audio shop carries the tube as well) and your good to go. I found you the install manual, just copy and paste(make sure all wires are connected with keys off the ignition until everything is good and connected)
http://resources.jvc.com/Resources/00/01/50/LVT2173-002A.pdf
Jul 14, 2011 | JVC Car Audio & Video
I am attempting to install an after market stereo in my 1997 Lincoln TC. The wiring diagrams I am finding online are not matching the wires (in the dash) from my market stereo? There are two black wires,...
you can go to radio shack or other store and buy a plug adapter for your brand of radio that will match both the radio and the cars wiring so all you have to do is disconnect the factory radio and plug in the adapter to the radio and the original car wiring plug and your set to go without figuring out which wires to connect to and removing the possibility of causing wiring problems with the car
Mar 02, 2011 | 1997 Lincoln Town Car
Need to figure out what wires r what from the radio
you need to use the right adapter for your car and that radio. you don't want to mess with the wires. get the right adapter and avoid damage to the radio and/or the speakers or maybe a car fire
May 23, 2010 | 1999 Ford Taurus
Trying to install a new pioneer radio to a 1999 jeep
try walmart they have the wiring harness that you need to install your radio for about 6 dollars
Aug 10, 2009 | Pioneer DEH-1100 CD Player
My factory radio went out in my car...so i had a new one put it in. After the guy installed the radio we noticed that my park lights and dash lights werent working. We checked the fuses and they were all...
I really hope that this guy bought a wiring kit to put in the aftermarket radio, because this could be simple. Your stock radio runs the dash and parking lights threw it's display and that needs to be looped with the new radio. On the aftermarket, there is a orange wire that does this. Since the stock wiring is different with every make and model of auto out there, you need to buy the wiring kit that plugs into the car's harness and matches in color to the harness of the new radio. Putting together the orange wires will give you back your lights. If this person cut the orginal plugs off of the car and wired it direct to the car, you may want to see if the plugs can be put back on and the wiring kit installed or you going to be going through a nightmare of figuring out what wire is what on the car side. Those wiring kits that plug into the car and wire up to the radio are cheap and can be bought at Wal Mart for about 20 to 25 dollars. Good luck
Aug 09, 2009 | 1999 Honda Accord
Gauges dont work after new cd player install
you will have to go to the gm garage and ask for the wiring diagram to match the wires up. but the way to fix it the right way is to go to the junk yard and cut the harness out of a car and splice the wires back together then go to wall mart or best buy to get the right wiring adapter then you can match them colors up to your new radios wires and plug into your car
Mar 09, 2009 | Buck Oldsmobile Intrigue 1999 Radio...
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
Pyle PLCD78M Car CD/ MP3 Player Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
