Question about Sony NWZ-E436F MP3 Player
My sony walkman NWZ-A729 keeps getting a "This device cannot start. (Code 10)" in the hardware manager. I keep trying to use the MTP driver but everytime it does, it works correctly for 10 seconds but then it just says "creating library" and goes right back to not working. I tried using it as a usb mass storage device, but I really don't want to use it that way. I got it to work on another computer so this isn't a problem with the player itself.
SOURCE: MTP DEVICE Sony 4gb walkman NWZ-S616 not installing
simple when the pop up of the installation window comes up..
just say search for drivers manually..
then go ahead and choose the bottom options on windows..
and its gonna config the device to be a mass storage device..
then you just drag and drop or use WMP..
i know its not a complete explaination but just mess around with it works! :) cheers took me 2 hours and it was that easy haha!
Posted on Jun 09, 2008
SOURCE: My Computer doesn't recognize Sony NWZ-B105F Walkman as
Finally found a solution on these forums.
http://www.fixya.com/support/t601752-sony_walkman_nwz_b105f_mp3_wont_connect
Posted on Oct 18, 2008
SOURCE: I installed my sony NWZ as MTP device, but now i want to go back
Since there's no easy option in the Walkman's settings to switch back and forth between MTP and UMS, there's a little trick to un-do the MTP drivers so that the unit becomes a straight USB Mass Storage drag/drop unit. You have to go into Device Manager (Windows XP), find the Walkman in the Portable Devices group, right click, then select Update Driver. Then select "No, not this time", then Next. Select "Install from a list or specific location (Advanced) then Next. Select "Don't Search, I will choose the driver to install", then Next. (Be sure to check the box beside Show Compatible Hardware) Highlight USB Mass Storage Device, then Next. (To revert back to MTP, just do the same thing but choose MTP instead of USB Mass Storage Device.) Personally, I'd never go back to the MTP mode. Having the Walkman seen by the computer as just another USB mass storage device allows the drag/drop transfers to go much faster
Posted on May 05, 2009
SOURCE: My Sony Walkman NWZ-E436F shuts off after creating the library
Hi I had the same problem and I finally figured it out.
First you will have to try to connect to the computer by pluggin it in and reseting once the computer recognizes it you should be able to look at the files.
If you are able to get the device to this point;
1. create a folder on you computer it could be in you desktop or document and name it something you would remember to go to. I named mine SONY.
2. copy all the folders from your WALKMAN to this folder;
3. delete all files from your WALKMAN there are some files it will not allow you to and just hit SKIP.
4. download the Firmware update (1.02) from the SONY Suport website: http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWZE436F and select your computers operating system and download the file.
5. Once you download it run it and it should re-install all the necesary files back to you device.
6. Re-start the WALKMAN and it sould work just fine now you can go back and add your music files and photos, etc...
Good luck this worked perfectly for mine.
Posted on Oct 07, 2009
  • 65 Answers
SOURCE: Sony Walkman NWZ-E436F will not connect to PC or
First reset yours by the Back button;
If not solved;
Reset again by the button, the On the Computer by Fat32 Format, and then Copy the Initial Files that were on your MD when you Bought;
Good luck
Posted on Nov 04, 2009
Nwz-e344 sony walkman isn't being recognized by my computer
If your PC has windows XP sp2 or later and Windows Media Player 11 try to do these steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | Sony Walkman Video NWZS615F MP3 Player
Driver for sony b105f
You don't need any driver if your PC has windows XP sp2 or later and Windows Media Player 11.
Try to do these steps:
I hope this helps.
Thanks.
gylacz
Aug 31, 2011 | Sony Walkman NWZ-B105F MP3 Player
I had my sony walkman nwd-b103f. when i connect it to the pc it say's usb device not recognized. plz help?
Please try these steps:
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
Thanks.
gylacz
Aug 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
Sony NWZ B153F Mp3 player is not recognized by windows XP system
Your pc should have windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
Thanks.
gylacz
Aug 11, 2011 | Sony Walkman NWZ-B103F MP3 Player
Hi i m deep chhetri 4m nepal. my sony nwz-w202 dont show while conect to pc . when i formate device,then this problem device driver software was not instal successfully
If your pc has windows xp sp2 or later and Windows Media Player 11, please try this procedure:
I hope this will help you.
Thanks.
gylacz
Aug 02, 2011 | Sony Walkman NWZ-W202 MP3 Player
My sony nwz-b152f is not accepting .i need adriver for that
Good work and luck!
gylacz
Jun 24, 2011 | Sony Walkman NWZ-B142 MP3 Player
Need driver for Sony walkman NWZ-B152F
Thanks.
gylacz
Jun 06, 2011 | Sony Walkman NWZ-B142 MP3 Player
Widowsxp does not connect NWZ B135F Walkman
Thanks.
gylacz
May 22, 2011 | Sony NWZB135F MP3 Player
My sony nwz-S616F doesnt transfer songs from pc
Sony NWZ-S616F
Dear holders, I have it and solved all problems which are in discussion. Just read all INFERNAL help, it works! By XP, go to Start-Control Panels-Administrative tools-Computer Management-Device manager (small icon of computer on your left hand side) tab should have “Walkman” or MTP device. Right click on it and go to properties, now before doing anything it should say “Location — —— Location 0 (Walkman)” if not try unplugging the walkman and see if the MTP device you’re looking at is removed from the list, just to make sure it’s the right device we’re looking for.If you’ve confirmed it’s the Walkman, click on the “Driver tab” and click on “Update Driver…”. Then click on the “Install from a list or a specific location (Advanced)” option and click “Next”. Now select the “Don’t search. I will choose the driver to install.” and click next. It should now bring up 2 driver choices, one being “MTP Device” and the other “USB Mass Storage Device”. Select the USB option and select next, it will then install your walkman as a USB storage device and after that’s done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in “My Computer””. Holla for original uploader Inferno!!!
May 08, 2008 | Sony Walkman NWZ-S616F MP3 Player
if you have a problem about MTP Device and wont be able to show in your "My Computer", here are tips that may help you fixed your problem:
*First- Uninstall the MTP Device Driver in your system.(Right click My Computer then manage, then click Device manager at the left part, then after that, find MTP Device in your right part, then click and Right click the name of your MTP Device then uninstall.)
*Second- Reconnect the device and then after a pop-up show which says, New hardware found,
click install the driver in a specific location, then choose the bottom option and then choose
Storage Device.
*Lastly- Turn On your Device and search it in My Computer.
that's all, and i hope i do a little help to you!
Mark Anthony Quintana
Dec 09, 2007 | Audio Players & Recorders
Sony NWZ-E436F MP3 Player Logo
192 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
