How do you replace the driver side brake lightbulb on a 2000 Subaru outback wagon.
All you need to do is remove the clip holding the washer fluid neck filler, once this is out of the way you can access the big gray backing that should have two wires coming out of it. just twist in the direction indicated and remove the cap, now you have access to the back of the bulb, remove the wires attatched to it and remove the metal clip that holds the bulb in place. now just put the new one in. You will see a small tab on the round part of the bulb, below the glass, align it right in the slot and put the metal clip back on and put the wires back on and backing cap and washer filler cap. P.S do not touch the glass on the new bulb, the grease on your fingers will prematurely burn the bulb out.
russ7sly,
Where is the washer fluid neck filler? When I open the little plastic cover from the trunk to look behind the tail light, I see some wires. Do you have pics? I'm more visual.
Thanks.
