Question about LG WM-0532HW Front Load Washer
How do you remove the old bearings - LG WM-0532HW Front Load Washer
  • 111 Answers
You dont , yoy have to replace the back tub
Posted on Jun 26, 2009
Need to remove the old bearing from a 1994 ford thunderbird and replace it by hand. How do I do this and which direction do you go for removal.
bearing come out on the side they went in.
bearings r 2 pieces, the bearing and its race.
bearing is held in by some bolt arrangement so removing that allows bearing to come out.
race is press fit and requires a removing tool or access to the rear of bearing, a hammer and something to go between hammer and rear edge of bearing - then tap around edge to move it out.
Sep 21, 2014 | 1994 Ford Thunderbird
Replace wheel bearing front awd 2010 ford edge
remove caliper, rotor, caliper bracket, lower ball joint shaft and two strut bolts. remove bearing housing and any snap rings. remove old bearing. replace and repeat in reverse. watch the abs sensor! costly if damaged. This is not for beginners...
Sep 19, 2014 | 2010 Ford Edge
Z61 brush won`t rotate belt ok
Hartlepoolke:
Unplug the vacuum, turn it upside down and remove the floor plate so you can access the beater bar. Remove the belt from the motor shaft and remove the beater bar and belt from the machine. At each end of the beater bar there will be a small circular bearing. Carefully remove the bearings from the ends of the beater bar, and remove the collection of hair, carpet fibers and any other junk wrapped around the bearing mount studs. Grab an old pan... (something to wash the bearings in) and an old toothbrush. Scrub the bearings with the toothbrush dipped in rubbing alcohol, and attempt to spin the bearings by hand as you clean them. When the bearings will spin freely, dry them out, and put a drop of oil (preferably 3-in-1 or light machine oil in the bearing. Don't soak the bearing in oil, that will just attract more junk to jam the bearing. Wipe the bearings off and rotate them to ensure that they aren't ratcheting or siezing up. Check the belt to ensure that the motor spindle has not damaged the inside surface of the belt... If it has, a new belt may be in order. Reassemble the vacuum and you problem should be solved.
Aug 26, 2012 | Electrolux Vacuums
I need instructions on replacing the clutch in a '94 Chevy Blazer 4x4, 350 engine. Specifically the pilot bearing, throwout bearing.
The pilot bearing is pressed into the flywheel and you need a pilot bearing/bushing puller. Some A/P stores will rent it to you for free (deposit). the throwout bearing is held onto the clutch fork normally by clips. Sometimes you have to take the "fork" out to get the bearing off.
Make sure to note how "deep' the pilot bearing/bushing is so that when you install the new one it is set at the right depth.
Jan 01, 2011 | Chevrolet Blazer Cars & Trucks
Remove &replace 95 accord rear wheel bearing
remove this items in this order(rear disc):
-remove rear wheel(the side you are replace)(19mm socket)
-remove brake caliper with cailper bracket(14mm socket)
-remove brake disc
-remove metal cover hub/bearing assembly with flathead screwdriver
-remove 36mm nut behind metal cover.
-pull hub/bearing assembly out.
note:sometime the inner side of bearing stay on knuckle and you have to pry it out pry bar. check old bearing vs new bearing and you'll see the different. Don't reuse any parts of the old bearing.
-install new hub/bearing
Dec 15, 2010 | 1995 Honda Accord
How to change brake rotors on a 2000 Chev Astro
Unfortunately the rotors on the astro have an integrated hub, so you have to pull the whole thing, the just is just like changing wheel bearings.
Remove the wheel, remove the caliper, remove the dust cap, cotter pin and then remove the axel nut. Be sure to install new grease seals.
This is a good time to replace the wheel bearings, if you don't you should knock the old raced out of the old rotors and install in the new rotors with your old bearings.
Hope this help.
Sep 01, 2010 | 2000 Chevrolet Astro
Bad Wheel Bearing on a 1994 Toyota Camry should I also replace the abs sensor?
You should only replace the sensor if it is damaged. Most Japanese made vehicles have bearings that are pressed in to the wheel hub. Your local parts store should have a new hub assembly that comes with the bearings already pressed in it. If you know of a machine shop that will press new bearings in the old hub and remove the old bearings that may be a little less expensive. They need to be removed and installed using a bearing press. Please rate me on this answer.
Jun 28, 2010 | 1994 Toyota Camry
How do I change the front wheel bearing on 2003 ford focus zx3
Remove the spindle, remove the hub from bearing, remove lock ring, press old bearing out, press new one in, if old hub is reusable, press into bearing, reinstall spindle.
Jun 27, 2009 | 2003 Ford Focus
Removal and Installation of Bearings (Front Hub)
these must be pressed in and out. u will need to have a machine shop remove the old bearing and install the new bearing
Jun 01, 2009 | 1991 Ford Festiva
Washing Machines Logo
97 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
