2001 Honda Accord Ex needs freon. Need PSI reading
2001 Honda Accord Ex, 4 cylinder needs 134A freon. I need to know the proper PSI that should be shown on the manifold gauges with an outside temperature of 85 degree.
  • 96 Answers
SOURCE: Need to add Freon cannot connect manifold high or low side.
yes there is an adapter to reduce to fit 410a hoses, go to a HVAC supply company they have them
Posted on Jan 15, 2009
johnsmith992
  • 37 Answers
SOURCE: My 2001 Honda Accord will not start, do I need a new starter?
if you turn the key and engine fails to budge ,are you getting a clicking sound as if their is life from your startermotor ,if so maybe your solenoid is sticking which is part of your starter. give it a tap with a hammer .if it doesnt cure the problem than your starter is faulty. or even select nuetral on your transmission and try then.
Posted on Jan 29, 2009
csmock132
  • 4669 Answers
SOURCE: 1996 Honda Accord need to change transmission fluid and filter...
What fluid are you changing? What engine?
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: I need to know where the coolant sensor is on the
find the thermostat housing and look on the radiator
Posted on Apr 21, 2009
  • 84 Answers
SOURCE: 2000 honda accord ex v-6 3.0 engine........won't start in hot wea
replace main relay
Posted on Jun 25, 2009
Testimonial: "good call right on the money......thanks"
CIVIC EX 1.7 LITER ENGINE 4 CYLINDER/JUST QUIT RUNNING ACTED LIKE OUT OF GAS. MECHANIC SAID WAS ALTERN ATOR I BOUGHT NEW ALTERNATOR AND THEN HE SAID needs fuel pump bought new fuel pump and now says...
I don't know about logical, but it sounds expensive. I do
as much as I can for my 05 Accord, but when I can't
handle a problem, I take it to Honda. Not saying their
mechanics are any better than a local service station,
but most problems are repetitive, and Honda only works
on Hondas and have the proper diagnostic equipment.
Jan 20, 2011 | 2001 Honda Civic
Air conditioner does not cool in 2000 Yukon.How do I check freon level and how to replace freon if need be
Get an r134a refrigerant add kit from Walmart or your local auto parts store.
You can even get a can of Arctic Freeze by Intermatics that has a hose and a gauge on it.
Connect the hose to the low side port. You can find this port on the 'thicker' piping that comes off of the compressor (versus the thinner piping that comes off the compressor which is the high pressure side).
Pressure should read 25 psi to 45 psi on the low pressure side when the compressor is running and the a/c is on.
Pressure should read 75 psi to 100 psi on a hot day when the car is off.
However, you'll want the a/c to be running when you add freon.
Press the button on the can to install more freon, if needed.
Aug 19, 2010 | 2000 GMC Yukon Denali
How do you add freon to a 1992 Honda Accord LX?
In 1995 they switched to R-134a coolant,Unless your system has been completely replaced to update to current requirements,you need to go to a shop.If you have a new system,please let me know and I will tell you how to do it.Good luck! Greg
Aug 09, 2010 | 1992 Honda Accord
The air conditioning doesnt work it just blows hot air even with the ac on. i dont know whats wrong with it if everything needs to be replaced or just something simple. i know nothing about cars
What I would try first is recharge the a/s system, your car came with R12 freon, that type of freon is impossible to get these days, so you will need a retro fit kit to convert it to 134A freon, the kit will have two 134a fittings that screw on to your R12 port, so that the 134a recharge hose will go on, the low side will be the one your add freon through, it will be the thinker hose of the two, the thin one is the high side stay away from that one, you will also need one can of freon (134a), if it works, it might work for a while till the freon leaks out again, then you will have to take it it for repair, but this way you know it's just a leak and every thing else works.Good luck, let me know if I can be of more help.
Jun 27, 2010 | 1992 Honda Accord
1998 honda accord ex air conditioning not cool
Did you check the condensor fan to make sure its working
Apr 17, 2010 | 1998 Honda Accord
WHAT TYPE OF FREON DO I FILL MY AIR CONDITIONING UP WITH ON A 1997 HONDA ACCORD
Use 134a freon,be sure to add oil also,if the freon was lost,so was some oil,use a 4 oz can of pag 46 oil charge.
Apr 16, 2010 | 1997 Honda Accord
How many psi of freon does your 1995 honda accord lx need
People, he asked for the psi, not how to do it and everything else. High side, 35-50 psi. Low side 20-35 psi. Very simple question to answer. He likely knows how to do it, just needs the psi for high and low.
Mar 02, 2010 | 1992 Honda Accord
2001 Honda Accord EX-4 cylinder
remove the hose ...this is to the radiator correct just make sure the motor has not been Running or you will get burnt also use a pan to collect the antifreeze and refill the radiator
Aug 24, 2009 | 2001 Honda Accord
Heating & Cooling Logo
432 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
