Question about Pioneer DV-09 DVD Player
Will not turn on.
Have service manual and checked all power supplies. When unit is plugged in the standby light comes on. When you push power, the light goes off but the "power on signal" is sent to the IC\'s and the clocks start up on all of the IC\'s. The reset signals seem to be all there too. But no lighs and no functions. Any suggestions?
  • vbartone Dec 29, 2008
    After cutting off power for a while, when power is reconnected, the "stanby" light comes on. Then when you turn on the unit, nothing appears in the LED window, and the "standby" light BLINKS, about once every 10 seconds. I can't find a manual that tells me what a slow blinking standby light means...
willwildy1
  • 5 Answers
SOURCE: tuning
John,
Enter setup from the front panel or remote. Go to auto tune and select it. from here your tv will select the channels available on your cable line or from off the air. Wala your tv is tuned.
Posted on Jan 21, 2008
robotek
  • 1512 Answers
SOURCE: Tuner doean't appear to be using 525 NTSB setting for auto channel tuning
It certainly looks like it should work according to the manuals. There are firmware updates available for this unit. Or you may have to take the unit to a pioneer agent to have it sorted.
The tuner may be faulty also. The agents would be able to check this for you. You could try to get to the source direct
support@pioneerfaq.info
Posted on Jan 28, 2008
  • 138 Answers
SOURCE: I have a John Deer L155, just tuned it up new
This problem sounds like you may not be getting fuel. This tractor may have a fuel shut of solenoid in the carb float bowl. if this is the case... after then engine warms up and the solenoid gets hot it may have a open in the coil and will not open the needle valve in the carb until it cools off. Easy way to check this is when it does not start for you turn the ign key on to run and then back off you should here a clicking sound if the solenoid is working. If you dont hear a clicking sound the solenoid is probably bad... you can prove this by waiting for it to cool off and trying the same thing if you hear the solenoid valve actuating then the solenoid is bad
Posted on Aug 15, 2009
ladywinn
  • 5138 Answers
SOURCE: My Warfdale 19" LCD TV
Problem will be either bad capacitors that are vented or puffed up on Top or you need to replace the main board the one you connect cable to Encompass Parts Distrbution might have it on stock
1-800-638-3328
Posted on Aug 23, 2010
Demonic-2011
  • 508 Answers
SOURCE: The DVR would not power up. I replaced c17,c19
Usually when replacing capacitors in a switchmode power supply, it is recommended that ALL the caps be changed in one go, rather than just replacing a couple (it is possible that the PSU is not fully functional since you only changed a couple of caps, therefore putting stress on other components such as diodes etc. hence why it won't stay on for longer than 5 seconds).
I suggest that you go with the easiest (and cheapest) option first - replace ALL the electrolytic capacitors in the PSU, this may totally solve your power standby problem - and the unit should remain on and function properly.
I also suggest replacing the 3 caps you already changed (C17 C19 C23) with fresh ones along with every electrolytic in the PSU - see if the unit remains on after that. If the unit still goes back to standby or shuts off, then check all of the other components (including any IC regulators and diodes). in the same circuit.
Where some electrolytics have strange values, replace with increased capacitance value and/or working voltage of each as required (note the value/voltage etc., of each of the original caps before you change them).
The good news here is if you do the above suggestion, and it works out well, all it will cost you is a bunch of capacitors and/or other parts as needed. No workshop charges if you do the repair yourself.
Fingers crossed that all you need is the abovementioned caps; but you need more than 3 to complete the job.
Posted on Apr 16, 2011
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Singer TV Model 20LNC
while it goes off does it make a ticking sound?
Jun 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Tv will not turn on
This set is pretty complicated my friend. You will need to check the standby power supply on the F board for the proper standby voltages. If they are good, your problem is most likely on the G1 main power supply board. I do have a service manual for this set if you know how to read them. It will save you about 30 bucks, if you want it from me. Leave your e-mail address and I will share it with you. Good luck with this repair.
Jul 04, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
No standby light
Depending on the brand and MODEL number here is what I think happened.
All TV sets have a Standby power supply. It runs all the time even if set is off but plugged in.
It supplies among other things the power (usually less then 12 volts DC to run the remote circuitry---It usually is not fuse protected so if a strike hit nearby it may have come in via the power cord.
Trouble is almost certain to be in the standby supply.
Mar 17, 2012 | Televison & Video
Xbox 360 elite has suddenly stopped working and doesnt light up
check you have a light on the power Brick. Usually Orange On Standby.
Push power On Button, should turn green.
No Light At All Check Plugs Fuse.
Orange light On, but not turning on, or going to Green, power Up.
Suspect Faulty Power Supply Unit, Or Motherboard Fault.
Mike @ Compurepair.
Mar 25, 2010 | Microsoft Xbox 360 Console
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Unit will not power on.
One or more sections of the power supply are not coming on. This unit has both fuses and ICP's (integrated circuit protectors) in the power supply that may open up causing your symptom. You will need to check and/or replace any open fuses or ICP's. If they immediately open up again, you will need the manual to figure out what is loading the power supply, or what component in the power supply has failed.
Oct 04, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Tv wont turn on
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3785TA POWER SUPPLY BOARD MLT386X
Oct 02, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
Jun 06, 2006 | RCA RT2500 System
Pioneer DV-09 DVD Player Logo
120 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
