Question about LG WM2016C
Lg washer smells like rotten egg. - LG WM2016C
  • 4 Answers
Go buy a small bag called "shock" for a pool.. it is only $3 at home depot.. just add 1/4 cup on an empty cycle with hot water.. it will scrub your plastic and stainless clean.. i have my wife add a teaspoon to all my clothes.. our towels would smell moldy a couple hrs after getting out of shower. now they have no smell anymore.. no smells comming out of washer either..
Posted on Jul 07, 2009
2 Suggested Answers
SOURCE: Rotten Egg Smell
Let me guess, you smell it when you use hot water to wash? sounds like it is more of a hot water heater problem with the rotten egg smell you mention. This happens when the "sacrifical rod" in your hot water heater needs replacing. Inside every water heater is a long magnesium bar called an anode rod. The sacrificial metal protects the tank from rust by corroding first. Once the bar disintegrates, however, the tank begins to corrode. You can at least double the life of your heater by replacing the rod before it dissolves completely ? every four years or so, depending on your water quality. Hope this helps. Joe
Posted on Jan 21, 2007
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
Rotten egg smell/sewage smell in restaurant
check for dead rodents in the ceiling. Have a plumber check for blocked /leaking drains especially around the dish washer drains . If you have had pest exterminators in lately then something may have taken the bait . IT will be best to get in professionals to remove the smell as quickly as possible as to customers a smelly restaurant is equal to bad hygiene and food poisoning.
Feb 20, 2014 | Home
Truck is giving off a rotten egg smell !
rotting egg smell is associated with your cat converter going bad
Jun 24, 2013 | 2004 Cadillac SRX
My 2002 Pontiac GP V6 smells like rotten eggs from the exhaust
The rotten egg smell if it is coming from the exhaust is a very good sign that you catalytic converter has failed or is failing. but a bad or battery that is being overcharged can also make a rotten egg like smell.
Jun 05, 2011 | Pontiac Grand Prix Cars & Trucks
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Mar 17, 2010 | Home
Rotten egg smell / sink
Two different problems. Rotten egg smell is sulfer from the water supply, especially strong in heated water. Drain may need to be cabled out.
Mar 12, 2009 | Plumbing
Rotten Egg Smell
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Nov 02, 2008 | LG WM1814CW Front Load Washer
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
LG WM2016C Logo
1,048 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
