Question about Fellowes Office Equipment & Supplies
We have a PS-6SC shredder. We were shredding lots of docs and it got jammed. I can see some tiny bits still in the middle but can't reach them. Reverse doesn't clear the jam. How do I get it out?
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
  • 883 Answers
SOURCE: Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Posted on Jun 21, 2007
SOURCE: Shredder suddenly runs only in reverse
I had the same thing happen to me today - I had just shredded a ton of stuff, emptied the bin 4 times - after emptying the bin the last time, all of a sudden it would only go in reverse. I pulled out my instruction manual and it says the motor might overheat and to let it cool down and try again. I let it cool down for about 1 hour, cleaned out the gears and dusted off the sensor and it started working even better than it did before.
Posted on Jan 30, 2008
SOURCE: Shredder won't shred any more.
You might have broken the actual mechanism enabling it to move forward. To be honest, your easiest solution would be to buy another shredder rather than attempt repair if this is the case, they're so cheap now.
Posted on Mar 27, 2008
  • 329 Answers
SOURCE: Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Posted on Jun 24, 2008
Why doesn't forward shredding work?
  • The jam was not cleared completely
  • The shredding mechanism was damaged in the process of clearing he jam
Nov 28, 2015 | Royal 150MX Cross-Cut Shredder
Shredcare com
Many shredders will jam up with pieces of the shredded bits sticking inside. If it gets near the trigger mechanism that is pushed inside so that it can be pushed, it STOPS! Unplug it, use tweezers and gently but consistently try to pull out all the remnants. If you get it all out, and it can take a while, it should start up again. In the future oil the machine with the special oil they make for shredders sold where you bought the shredder... and only shred a few pieces at a time. Go backwards only to UNJAM. If it is jamming you have to fat a load of paper going through.....GOOD LUCK!
Jul 25, 2014 | Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Jammed shredder
If your Ativa shredder has a bin, you can gain access to the shredding mechanism by removing the bin and turning the shredder upside down. With power disconnected, be prepared to spend considerable time picking out bits and pieces of material. Tweezers and a utility knife are useful tools. Eventually your shredder will be back in working order.
Feb 28, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
Staples TXC22A. Why does Jam Light prevent shredding?
Your meticulous cleaning may have overlooked embedded residue from coated paper or paper laminated with plastic. It may be necessary to use a sharp pick and even a utility knife to remove the material bit by bit.
Feb 05, 2013 | Office Equipment & Supplies
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    Au845xb how do i open it to empty?
    there is a lip at the top of the tiny window on the front. Pull it forward like you would pull a file cabinet drawer open. it might take a bit of muscle if it's jammed full of shreddings.
    Nov 29, 2010 | Aurora Electronics AS1018CD Shredder
    Only one-half (righ side) of the shredder works, left side does not shred
    Fellowes has a five year warranty on the cutting block of their shredders. (The cutting block is that part of the machine that actually does the shredding of the paper) Take it back to the store where you bought it ans they should either replace the cutting block or exchange the entire machine, but it will take about a week or more, depending on where you are located. At least it shouldn't cost you anything.
    Sep 05, 2007 | Fellowes Powershred 480 Shredder
    98 people viewed this question
    Top Fellowes Office Equipment & Supplies Experts
    quennie732
    Charles T Nevin
    Charles T Nevin
    OfficeServiceAjnc
    OfficeServiceAjnc
    Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
