Question about Bosch Floor Scraper for Sds-Max Hammers HS1918
Does hs 1819 bosch floor scraper work for tile removal from concr
What is the best chisel to use in 11316 evs sds max hammer drill? Thank You!
stug_57u
  • 99 Answers
SOURCE: Broken chisel
The rubber end cap should just pry of the toll holder. Behind this ther is normally a snap ring or ciclip. Remove that and the chuck parts should all come off. Remember which order they were in. There is normall end cap, clip/ring, thick washer, dished washer and ball. Once all these parts are removes you can try and punch the bit out from the hole the ball sits in. If it doesn't come out like that then you would probably have to take the gearbox of and remove the striker from the tool holder and punch it out from behind.
Posted on Oct 25, 2008
  • 101 Answers
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Posted on Dec 16, 2008
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
comax
  • 154 Answers
SOURCE: i have a bosch rotary hammer 11245evs and it was
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Posted on Apr 16, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
How do I break up old bath room tiles
The common method is to use a small electric demolition hammer, like this
http://toolguyd.com/blog/wp-content/uploads/2013/05/Bosch-DH507-Demolition-Hammer-Tile-Removal.jpg
They can be easily hired if you are in a city. You can get various points for it, from spear to wide chisel.
http://images.makita.co.nz/_productshots/accessory/B/bits-chisel-M.jpg
If laying more tiles after, keep the undersurface as level as you can. Wear ear and eye protection. If your hands start to tingle while using the hammer, take a break.
There is a machine the pros use too, a power scraper
http://img.diynetwork.com/DIY/2003/09/18/adi609_3fe_lead.jpg
Jun 24, 2016 | Saws
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
Makita sds max avt --when it is on the chisel only mode it still revolves like in drill mode . What has caused this ?
If the bit turns freely it's possible you have the change ring in the forward position. The HM0860C is a demolition hammer, not a rotary hammer so the bit should not be rotating under power for any reason. On the HM0860C the changing ring on the nose does slide forward to let you choose and lock the chisel bits in 12 different angles. Check to make sure the change ring is in the locked position.
Jun 30, 2012 | Makita HM0860C 11lb Demolition Hammer SDS...
Dewalt 36v SDS 234 drill issue! Could someone please help? When I pull the trigger on the drill the motor runs but the drive only turns for about 1 second and stops even though the motor is still running....
DeWalt says:
Number of drilling modes
3 modes. Rotation only, hammering with rotation, or hammering only with rotation stop for light chiselling applications in tiles and plaster and impact stop mode for rotary drilling only in wood and steel.
Maybe yours is doing the second one?
Dec 02, 2017 | Dewalt Drills
Where can I buy replacement chisels? No one to have them for my unit.
SDS Plus is a common connection end. Several companies make them. I have not heard of a carbide tipped pointed chisel. only a carbide tipped chisel blade and bushing tool. Hilti makes very good chisels that will fit the Bosch. Hilti's number is 1800-879-8000
Jul 28, 2011 | Bosch Tools Sds Plus Hammer Steel Carbide...
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Need sds to hex shank adapter. Where to buy?
If you have SDS-Max, ereplacementparts.com has one made by Bosch that'll go from SDS-Max to 3/4" Hex:
http://www.ereplacementparts.com/sds-max34-hex-rotary-hammer-adapter-p-165057.html
I'm having a hard time finding one that'll do SDS-Plus, though.
Aug 19, 2009 | Bosch Drills
How much oil and what type goes back in the bosch 11241 evs
The best way is to find a Bosch service center and get the oil change kit. P/N 1615437511 this comes with a small bottle of oil and a top cover gasket. All you do is remove the top cover dump out the old oil and pour in the whole bottle of the new stuff. Couldn't be more simple.
Aug 01, 2009 | Bosch 11241EVS SDS-Max Rotary Hammer
Bosch Floor Scraper for Sds-Max Hammers HS1918 Logo
407 people viewed this question
Top Bosch Hammering Experts
John Trevino
Mike
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
