Question about Fujitsu ScanPartner fi-5120C Pass-Through Scanner
Yes and No. I found the error code but not a fix.
Yes and No. I found the error code but not a fix. I have a scanner Fujitsu fi-5015C with the following error problem: Communication failed. Make sure that the power is on, the cable is firmly connected, and the scanner is not used by another application. For details refer to FUJITSU TWAIN 32 Scanner Driver User's Guide. (Code: DS42019).
4 Suggested Answers
  • 300 Answers
SOURCE: FI-5120C won't scan
Reboot your pc
Posted on May 18, 2008
yooperbud
  • 8637 Answers
SOURCE: How can I resolve this
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: TWAIN Driver Error
If the windows image acquisition service is running, stop/disable it and see if this helps with the apparent concurrency problem.
Posted on Apr 16, 2010
How to fix FUJITSU fi 5900C e18 error code Fujitsu fi-5900C Pass-Through Scanner
you need the detail code to e18 to determine the exact error.
First generate the error code again , then hold down the document thickness keys together.
The display should change to a two digit numeric .
You need this code.
Jun 15, 2015 | Fujitsu fi-5900C Pass-Through Scanner
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
What's wrong if i get error e9
E-9 error in Fujitsu fi-6670/fi-6770 is the Image Memory Alarm which implicates scanner memory malfunction.Turn off and turn on the scanner, does the same symptom still occurs? If yes, then you may have to replace the DIMM located at the memory slots on the CGA board. If the issue still persists after replacement of DIMM, then you may have to replace the Control PCA. I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 17, 2013 | Fujitsu fi-6770 Flatbed Scanner
Error e9 on fi 6770 means what?
Thanks & regards,
ScanCare
I need a solution to u1 error with detail code o5A in fujitsu fi-5900c scanner
Hello Marcus,
In Fujitsu fi-5900c scanner, Error 05a refers to JAM1 Sensor malfunction.You need to clean the two lenses of the JAM1 sensor with a cotton swab. Then check the performance of the sensor and also check sensor cable connections. This error also occurs if Pinch Roller 2 is installed left-right reversal. Check the same too. If the issue still persists, then you may have to replace the sensor.
If the above steps do not help, then you are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Feb 07, 2013 | Fujitsu fi-5900C Pass-Through Scanner
Cannot load drivers for Fujitsu fi-5015C, once loaded, computer restarts and when windows comes back up it states there is new hardware that needs software downloaded, rather than starting the new hardware...
kindly download the new drivers for fujitsu Fi-5015 scanner from the below link and if solved/unsloved let me know i will guide you to solve this porblem,or mail me in felixsimon22@gmail.com
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
regards
felix
Mar 21, 2011 | Fujitsu ScanPartner fi-5015C Pass-Through...
Im getting black lines on my paper.
YOU NEED TO GET THE SCANNER SERVICED TO REMOVE THE BLACK LINES AS DUST IS INSIDE THE GLASS
Mar 17, 2011 | Fujitsu ScanPartner fi-5015C Pass-Through...
Flashing U light
try resetting the device and power fleeing by pressing power button in on condition for 30 seconds this fix the problem
Sep 03, 2009 | Fujitsu ScanPartner fi-5015C Pass-Through...
Fujitsu ScanPartner fi-5120C Pass-Through Scanner Logo
684 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
