Question about D-Link DIR-625 (790069292637) Wireless Router
Dlink dir-325 router loses internet connection
My router puts me online and drops me periodically . How do I keep a constant connection?
  • 3,153 Answers
You may want to issue IP addresses.
The computer has to knock-on the routers door and ask for directions home as its address changes everytime it leaves home (switched off)
If you give it a permanent key to its own door it tends to be more reliable
The same applies to both wireless and wired connections.
Find the RUN command and type cmd
In the black screen that pops up type ipconfig /all
Take note of the number by "default gateway" and "DNS servers" then close the box.
Now find the properties for your connection if it is on your toolbar just right click it and then click status, then properties.
Scroll down to Internet Protocol (tcp/ip), highlight it and click properties.
If its not on your toolbar
Call up your control panel and select Network Connections
If you have more than one don’t worry
Right click the first one and select properties
Scroll down to Internet Protocol (TCP/IP) highlight it then click properties
There are boxes here where you are going to type numbers.
Click the "Use the following IP address"
If your default gateway (router) is lets say 192.168.2.1 Then I would use 192.168.2.10 as the first number
The second box is 255.255.255.0
The third box would be 192.168.2.1 (same as your router address)
The two DNS numbers at the bottom can be got from the numbers you wrote down early on when you just had the modem connected
E.g. 207.147.239.12
207.147.239.200
Now click OK
If you have more than one connection available then go to the next one. It may complain about the number already being used tell it to ignore that.and do the same EXCEPT the first IP I would use 192,168,2.11. The rest would be the same as before.
Now move on to the next computer and do the same again but this time in the first box I would jump by ten so the IP would be 192.168.2.20
Again if it has more than one connection then do the same as above and advance the number by one in the top box
Next machine same deal advance by ten.
Once you have all your computers done then shut EVERYTHING down
Power up the modem and WAIT until all the correct lights are on.
Then do the same with the router.
Now power up a pc and check that you can surf without problems
Posted on Aug 24, 2009
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
My laptop keeps losing signal, keeps disconecting. plus when pc was hard wired it too lost connection
have you tried downloading the latest firmware?
you can do so by going to
http://www.dlink.com/products/?pid=DIR-615&tab=3
click on support resources.
select your router model and download the latest firmware.
May 25, 2011 | D-Link DIR-615 Wireless Router
How can I change the channel selection on my router....it keeps dropping the internet signal. Is there something else I should try?
In order to change the wireless channel of your Dlink wireless router DIR-615 , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless Network Settings under which you can change the wireless channel and click on save settings at the top .
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | D-Link DIR-615 Wireless Router
I tried to connect to the Dlink N300 with my cell phones and it finds the wireless connection , however after i put in the password it doesnt connect to the router. I have tried this with various phones....
Connect a laptop wired to the N300,
If you cn go online it aint a router issue
Second try going online with a laptop
Third check the Signal Type
B/G/N
Keep it to automatic
Disable Router PIN
Try Different Security WEP/WPAPSK/TKIP
Jul 06, 2017 | D-Link DIR-300 Wireless Router
How to reset the security for a Dlink DIR-625 wireless router
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Internet connection keeps dropping
Two possible reasons
If you have hidden your network name (SSID) in the wireless configuration in the router and use WEP or WPA security there may be a bug that can result in extended disconnect periods. Recommended solution unhide the SSID and keep the WEP or WPA security.
Second there are numerous wireless devices in use. Keep your wireless phone base station away from your wireless router. Try changing the channel your router's radio uses to transmit -- Channels 1, 6 and 11 are preferred. Try one you are not using, if that does not work try the other. (If you can see the surrounding channels in you connection wizard you may want to start with one no one else is using)
Dec 01, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
D-link DIR-635 router
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link DIR-625 (790069292637) Wireless Router Logo
711 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
