Sound but poor picture (looks like a negative). Flickers
  • lwedderb Jun 26, 2009
    The problem is with the TV not the input as the problem persiste regardless of the input source.
  • 34 Answers
Is it a high def tv are the settings on your satalite box the same as on your tv ie both 1080i or both NTSC or Pal? Doing this should fix.
Posted on Jun 26, 2009
I have a buzzing noise when tv is turned on and the picture flickers
Check connections in rear of television if connections are good check condition of RCA jacks and other connectors.Lots of times poor sound and vision quality is due to cheap or damaged connectors and/or wireing.
Jul 17, 2011 | Televison & Video
TV turns on . Sound on but no picture. sometimes it flickers and i receive a picture but only for about 10 seconds. This happens with different sources ie tv,sat,vcr.
Its possiable that you may have poor solder connections where our STK ICs are resolder them and transistors they are big black ICs will have STK392-110 on them. I would First start out with soldering everything on convergence Board.
Sep 24, 2009 | Hitachi 50FX30B 50" Rear Projection...
Poor picture. looks like a negative. poor
If you go into the menu there should be an option to change the brightness and sharpness of the image
Sep 22, 2009 | LG 42PX5D 42 in. Plasma HDTV
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Screen flickers
Check for multiple poor solder connection on the sweep/power supply board.
or.
just need to balance the three colors red,green and blue that may help. remove the front covers and look for black module that have screw and focus controls just move little bit left or rightbe carefull because you can loose the picture.
Sep 24, 2008 | Televison & Video
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Thomson Scenium 52 inch television
This is no easy fix problem you need to take set to repair shop, this is a lot of problems with these sets cold solder ,poor connections,bad deflection boards, tuner boards, bad ribbon connectors etc etc ect......BAD Flyback Transformers.Normaly id say your hori out put was shorted but on these sets anything can happen. ThankYou for using FixYa. Have a NIce Day.
Feb 08, 2008 | Televison & Video
Negative picture,lamp indicator flahing 3 minutes after turning tv off
I changed my lamp in the 65dr650 but the picture still looks like a black and white tv and flickers
Jan 30, 2008 | Sharp 65DR650 65" Rear Projection...
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Jan 19, 2007 | Hitachi 43FDX01B TV
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
