Question about Canon i860 InkJet Photo Printer
I keep geting Service Error 1500 when trying to print
    President:
  • 2,306 Answers
I don't see an error 1500, error 5100 though means the carriage can't move right and left or there is grease on the encoder strip behind the carriage.The grease you can clean with a Q-tip, and also make sure there is no paper scraps on the right or left side of the machine...
Posted on Jun 26, 2009
I have a HP Photosmart printer and keep geting an error message :Oxc18a0101. I've tried 2 suggested solutions already and it did not work. Help
To cure it:
Hit * and # at the same time on your printer
Enter code: 123
Hit Right Arrow
Go to System Configuration
Hit OK
OK again
and OK a third time
Unplug power from printer
Unplug power from wall
Wait 2 minutes
Replug the printer
It should boot fine and be able to print again.
Mar 26, 2011 | HP Photosmart 3310 All-In-One InkJet...
Error - 5100 and 6A00 keep appearing. What should I do?
Error 5100 means an error occurred in the carriage encoder signal. Error 6A00 means an error occurred in the AP motor during purging operation. To fix these two errors you need to replace:
- Carriage unit (QM2-2922)
- Timing **** strip film (QC1-6394)
- Logic board ***'y (QM2-3078)
Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM
information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when
replacing the logic board ***'y.
- Carriage motor (QK1-1500)
-Sheet feed unit (QM2-2916)
-Purge unit (QM2-2925)
Feb 02, 2011 | Canon Office Equipment & Supplies
I keep geting a dns error code 80710102 on my ps3 what is this
Hi Sir
80710102 PS3 Cannot connect to the router with current IP information - Try rebooting your router
May 19, 2010 | Sony Playstation 3 (PS3) Console
My HPSC 1500 PRINTER , KEEPS INDICATING THERE IS NO PAPER , AND WILL NOT PRINT
Dear Sir,
This is the error of empty paper tary so u plzz fill paper and restart power of printer and try to print
Thanks For Your Time,
Apr 07, 2010 | Office Equipment & Supplies
Lexmark T642N - error message 900.00 Service RIP software
If you are geting the 900 error frequently you should verify the level of firmware ( engine and base code ) in you printer and update it to the latest version :
http://support.lexmark.com
If this doesnt solve the problem then you should verify the type of files that are printed.
You can also try to reinstall the latest driver for the printer this should also solve the problem.
Mar 18, 2010 | Office Equipment & Supplies
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I keep geting error 80010002 from downloding
it does that when you are trying to download undownloadable games
Jul 06, 2009 | Sony PlayStation Portable (PSP) Console
Will not print .
Which Canon printer are you using? Does the printer show up on your printer status panel. If you still have the driver install program for the Canon printer, disconnect the printer, uninstall the printer driver, cold boot the system (power off / power on), reinstall the printer driver, plug in the printer. The system should sense the new hardware and install the driver. This should correct the problem.
Apr 28, 2009 | Canon PIXMA iP1600 Printer
I received an error message reading: SERVICE REQ. EROOO3. I can't print any more and need to finish a manuscript today.
The message indicates a controller or print engine error has been detected. It's the internal electronic/logic board failing.
If power cycling or turning it OFF/ON does notclear the error message, service is required as the logic board needsreplacement.
here's a link for certified service center for your product.
Nov 17, 2008 | Epson Action Laser 1500 Printer
Align printer
Go to "Printers and Faxes" in the start menu. Then right click on your printer and click on properties. Then click on the tab called Maintenance. There should be a button to align the print heads. Make sure the printer is on and paper is in the tray before trying to align the print heads.
Oct 07, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
115 people viewed this question
old marine
old marine
