Question about Westinghouse L1975NW Monitor
Out of range
I clicked keep aspect ratio and now my monitor says out of range and i can no longer access the operating system to change it back. I tried booting in safe mode and it still said out of range. I have a LG2452t monitor and i was running vista black edition...any help would be greatly appreciated!!
    President:
  • 1,383 Answers
May ber it is screen resolution issue.
When you power up the computer press F8 key then enter in enable vga mode.
Then change screen resolution to 1024*768 then apply AND ok.
Posted on Jun 26, 2009
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
Change screen from wide to regular our cable guy put it on wide my control will no longer change it
Vizio has a set of buttons on the left side where you can access your settings and change the aspect ratio of your TV. Though why you want it changed is beyond me. Wide screen is for 16:9 aspect ratios. At 4:3 (Standard) you won't be using your full TV picture.
May 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
How do i enlarge the print on the screen
there are several things you can do, change the screen resolution, or change the size of the text, to do this go to Control Panel - Appearance and Personalization - Display then click the 125% radio button and apply. in versions of windows older than windows 7, this process may be slightly different, this option may be in the ease of access centre. if you have trouble changing either of these things type your operating system and change screen resolution or change text size into google. to change the screen resolution go to control panel and in appearance and personalisation click adjust screen resolution, this will make everything look bigger, try to keep near the same aspect ratio or photos and text will look distorted or stretched.
Mar 14, 2011 | AOC Computers & Internet
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
The letters on my computer r so small i cant read them, how can i make them bigger
You likely have your resolution too high.  I prefer my resolution high but I can read small writing easily.   To change this right-click your desktop and choose personalize then display settings  adjust to a lower resolution but try to keep the aspect ratio similar to the ratio of the monitor you are using or the image will look squished.  once you have finalized your decision you will have to tweak it using the controls on your monitor to stretch the picture out to the edge of your monitor.    Also you can use the ease of access in the control panel for an on screen magnifier, or simply increase the font size in personalize (left column) adjust font size (DPI) (dots per inch)
Nov 17, 2009 | Microsoft Windows Vista Home Premium with...
NEC multiSync 1700V as external monitor for Notebook Toshiba U205, Operating System Window Vista Home Premium. It displays only part (80%) of the picture compared with notebook's monitor.
Hi, if the 17 inch lcd screen is not a widescreen then the problem with the screen is possibly nothing more than the aspect ratio or resolution, which ever way you wanna look at it. All laptops have a widescreen type of ratio, so you will have to be either willing to change the resolution when you switch screens or setup different profiles, which you should beable to do through control panel, appearance and then personalization, you will then have access to it.
Nov 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Icons and screen not sized properly-too big and out of proportion
Right click on your desktop
Click Properties
Click on the Settings Tab
It will say resolution with a sliding bar, you can move that around untill you find the right aspect ratio. Try 1024x768..
Hope that helps let me know :)
Jan 05, 2009 | Acer AL1916W 19" LCD Monitor
Bought new screen today
Based upon the Operating System you can change the aspect ratio from 19:9 to 4:3. In windows you can right click anywhere on the free space on your desktop once the menu pop-up click on properties and then setting. once the window open choose the different resolution.
Aug 02, 2008 | Belinea 19" LCD Monitor
Aspect ratio
display setting
from the desk top right click and select properties, then select the settings tab then change your screen resolution display setting
Sep 16, 2007 | Acer AL2016W 20" LCD Monitor
Westinghouse L1975NW Monitor Logo
203 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
