Question about Canon PIXMA iP1600 Printer
Will the printer become damaged because repeated error message?
I purchased ink cartridges that i needed to replace the chip. once i put them into the printer, message kept coming up that cartridge was out of ink. since printer still printed, i ignored the message. now that it has repeatedly come up though, a new message error message was displayed - if i continue to use the printer with ink out it will damage the printer. my question is, will this really damage the printer or should i just stop the messages from coming up all together?
  • Canon Master
  • 4,338 Answers
Do a EEPROM initialization:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 26, 2009
HP printer displays printer will not print message. How do I get printer to print?"
It might be your print que backed up. Open it and clear any old print jobs. Then reboot and check the que again. try you print job again.
Jan 04, 2015 | HP Photosmart C6180 All-In-One InkJet...
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Hp 8600 missing or damaged print cartridge how to fix?
If you observe the error message "One of more ink cartridges may be missing or damaged", "Cartridge Damaged", or "Ink Cartridge Failure", "The following cartridges are not intended for use in this Printer", etc. then the printer is not recognizing the installation of the refilled ink cartridge(s) or 'smart chip' which is affixed to the rear side of ink cartridge is causing the detection issue. This type of issue can also be caused by a bent pin on the PRINTHEAD assembly or one (or more) electrical contacts are dirty on the PRINTHEAD assembly (especially if the same error occurs with a brand new HP ink cartridge). Typically, the problem is usually an incompatible smart chip which is affixed to the rear-side of the ink cartridge.
(1) It is first suggested you remove the respective ink cartridge from the printer and thoroughly clean the cartridge's smart chip's gold contacts/electrical surfaces using an isopropyl dampened lint-free towel. Ensure no ink residue is present on surface of the chip. Also ensure the chip is located in the proper position. Please refer to the 2nd photo on the following Inkjet411 support page - carefully inspect chip position to ensure it was properly placed: http://inkjet411.com/?page_id=1999 Following cartridge 'smart chip' gold contact cleaning, please re-install the ink cartridge and retest.
(2) Remove PRINTHEAD from printer and inspect for damage to contact pin(s) on the INSIDE OF THE PRINTHEAD ASSEMBLY. Please refer to printhead removal procedure below for reference. Often, you can gently bend the pin back into position to correct the issue.
REFERENCE: HP Officejet PRO 8600 Printhead Removal & Replacement Procedure:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02871867
SPECIAL NOTE FOR BRAND NEW HP PRINTER MODELS (temporary issue until approx. mid to late August 2014):
If you continue to observe "One of more ink cartridges may be missing or damaged" alert messages, please note that printer firmware versions CKP5CN1334ER for the newer HP Office jet Pro 8100 and 8600 printer series (manufactured after Nov./Dec. 2013) do not allow the replacement chip to function (this problem temporarily impacts brand new HP printers only -- this problem will be resolved sometime in June 2014 with the release of upgraded smart chips to all Costco stores which will work in the newer printer models).
Confirm if your printer is impacted:
1. Verify 8100/8600 printer firmware - print the PRINTER STATUS REPORT or PRINT QUALITY DIAGNOSTIC page to verify your firmware version.
2. To print the printer status report, on the printer control panel, press and hold the (Cancel) button for three seconds (i.e. 8100 models). Alternatively, you can print either of the reports from the TOOLS menu if this does work.....OR.......
3. Check 'Product Information' - 'Firmware Version'
a. CKP5CN1334ER for the HP Office jet Pro 8100 and 8600 printer series
b. If your printer has this printer firmware version, then you may be impacted.
If the error message persists then we suggest you return the cartridge(s) to your refiller and request to have the 'smart chip' (attached to cartridge) replaced with a new chip*. If Costco does not have the NEW CHIP VERSIONS yet, then request a refund for the refill purchase.
However, if the same problem occurs with a 2nd cartridge (or manufacturer's brand new ink cartridge) then the PRINTHEAD may either have ink on the internal electrical surfaces (where cartridge mates to it) or the PRINTHEAD may have a bent or deformed contact pin. Remove PRINTHEAD from printer and inspect for damage to contact pin(s) on the INSIDE OF THE PRINTHEAD ASSEMBLY. Refer to printhead removal procedure below for reference. Often, you can bend the pin back into position to correct the issue.
You should also ensure the EXTERNAL electrical contacts on PRINTHEAD are clean of any ink residue. Clean with damp towel to remove residue. Refer to the 5th photo on the following Inkjet411 support page: http://inkjet411.com/?page_id=1999
ADDITIONAL ERROR MESSAGES / NOTES:
2. An "Ink Cartridge Depleted" message can be observed (printer will cease print operations) when an ink cartridge 'really is' out of ink. HP has small sensors which look into the bottom of the ink tank to ensure ink is present. Typically you will receive 'Low Ink Warning' messages just before this occurs.
3. Since the printer monitors ink usage/drop counts, it will display the 'Ink Sensor Warning' messages when it 'predicts' the cartridge should be out of ink, but these messages can be temporarily ignored and you may continue printing. Eventually the 'Cartridge(s) Depleted' alert message will be displayed when the cartridge truly is out of ink.
4. The "Use Color Ink Only" or "Use Black Ink Only" messages can be caused by poor contact (i.e. electrical connectivity) between the ink cartridge's 'smart chip' and the carriage assembly (which the ink cartridge plugs into). Typically a 'Red X' will also be displayed on printer control panel LCD or Window's pop-up screen when this condition is present.
*This type of error may be caused an electrically damaged 'smart chip' which is affixed to the rear side of the cartridge itself, a mis-aligned chip (wrong position), an incorrect replacement chip type (i.e. operator installed the wrong chip on for that color and/or tank size). In most case the cartridge will need to have a new replacement chip installed by the refill operator. We apologize for the inconvenience if either of these possibilities prove to be the root cause. For more information on chip placement, refer to Section A on the following Inkjet411 support page: http://inkjet411.com/?page_id=913
COMPATIBILITY NOTE: Compatible (clone) HP 950/951 ink cartridges, sold via the internet or similar, may not be refilled and reprogrammed successfully - Costco does not (should not) support refilling of compatible ink cartridges (i.e. those cartridges which do not have the HP original blue/black logo displayed on the front label of the ink cartridge). If you had a compatible/clone/remanufactured ink cartridge refilled we cannot guarantee it's performance.
Please let us know if this does not remedy the current error condition. For any additional questions please contact us directly: Inkjet411help@gmail.com
If you need to purchase a new ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
-Thank you
Inkjet411 Team Member
Aug 01, 2014 | HP Officejet Pro 8600
How to fix hp 8600 damaged cartridge message?
*This type of error may be caused an electrically damaged 'smart chip' which is affixed to the rear side of the cartridge itself, a mis-aligned chip (wrong position), an incorrect replacement chip type (i.e. operator installed the wrong chip on for that color and/or tank size). In most case the cartridge will need to have a new replacement chip installed. For more information on chip placement, refer to Section A on the following Inkjet411 support page: http://inkjet411.com/?page_id=913
If you need to purchase a new HP 950/951 ink cartridge, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
-Thank you
Jul 31, 2014 | HP Officejet Pro 8600
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
I just got my ink cartridges refilled and when I put them in my computer says check ink UP051. Even when I took the ink out and tried restarting it, it gave me the same error message.
A number of printers simply will NOT work with "Refilled" ink cartridges. This is because some have a "Chip" inside them that will not allow this to be done. They want you to buy their ink.. and buy a new cartridge each time... SOME places that refill them are able to reset the chip. However "They" have us all by the "Goolies" and as much as you may hate it the best way is to buy a new recommended cartridges. Sux huh?
Feb 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I have refilled the cartridges on my HP Photosmart C4280. I know this is not advisable but I'm afraid I can't afford their prices. So far so good - it seems to print fine, my problem is that I still...
When refilling an inkjet cartridge that contains a chip, the chip records when the cartridge goes low and then empty. The chip needs to be replaced to eliminate the low or out message. You can set the printer to continue printing when it receives an out message even though there is ink available. However if you do run the printer and there is no ink flowing it can cause damage to the prinheads.
Nov 05, 2009 | HP Office Equipment & Supplies
Canon PIXMA iP1600 Printer Logo
75 people viewed this question
old marine
old marine
