Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 2018D
When I turn on Ricoh Aficio 2018 locks and show SC500 error.
Any sugestion?
  • Anonymous Mar 19, 2014
    my ricoh 2018 asks me to replace tonner and the tonner is still full what should i do
  • Anonymous Mar 27, 2014
    how to turn off ecm mode
  • Ricoh Expert
  • 398 Answers
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
-Carl, please let me know if this helps.
Posted on Jun 27, 2009
    Problem Solver:
  • 19 Answers
Pull the motor out of the machine. In the inside there are four gold wires one or more have a bad contact.
Posted on Sep 01, 2009
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Error 36851: No response from scanner" ricoh
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
My Ricoh 1018D is showing an sc500 error code. what could be wrong?
SC:500 Main motor lock
Symptom: A main motor lock signal is not detected for more than 7 consecutive
checks (700 ms) after the main motor starts to rotate, or the lock signal is not
detected for more than 7 consecutive checks during rotation after the last signal.
Possible Cause:
• Too much load on the drive mechanism
• Main motor defective
IMPORTANT: From my experience I tell you disassemble the image unit and check for worn gears. If not replace the main motor.
Feb 02, 2011 | Ricoh Aficio 2018 Copier
Error 500 ricoh 2018
sc 500 is the main motor error. replace the main motor at the back. it will solve the problem
Jan 04, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018 shows functional error 670
SC670 is an engine start error. If it only happens once, it could just be a hiccup in the system -- reboot the copier and see if it goes away.
If the error recurs, try reseating the connectors on the copier's main boards. If that doesn't work, either the engine board or the controller board will probably need to be replaced.
Jun 17, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh aficio mp2000
Turn off the power for at least 5 to 10 minutes and then on. That code means that the main motor is locked.
Jun 01, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
581 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
