Question about Yamaha Full-Size Keyboard
Dead HS-4 I, too, had a dead organ. Gone since I got it. My mother said it hadn't been working for a number of years. Then, this a.m., I jiggled the power chord (under the right side of the keyboard) and it came on! I didn't believe my eyes at first, since I had done this about a year ago and nothing happened. It's as if it miraculously came back to life! I thought all the moving around had killed it, but I guess I was wrong. I'm going to have tech look at it.
    Sergeant:
    Champion:
  • 233 Answers
Why should you go to a tech if it works fine??
Posted on Jun 26, 2009
Hi,is it possible to upgrade the rhythm's and backing on an Electone HS organs/or similar. Thank you Chris
Chris, most likely yes, depending on the actual model. Best to contact Yamaha directly. Here's the link-
Contact Us Support Yamaha United States
Mar 07, 2017 | The Music
Yamaha Electone HS-4 doesn't remember settings
checked the internet and it states in the manual that if you do not use the organ for long time the user memory will be lost but the factory memeory will not be affected. check the below link:-
http://archive.org/stream/YamahaElectoneHsUsersGuide/YamahaHsUsersGuide_djvu.txt
Aug 30, 2012 | Music
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
Kustom KSC 4080 Just bought - channel 1 is dead, for both 1/4-inch and XLR inputs. By the way, the nut securing the 1/4-inch jack is gone (any wild possibility that creates a grounding issue that cuts out...
The missing nut is not likely to kill the channel. You just bought this so exercise your warranty... unless it is used in which case you bought someone else's problem. Somebody probably blew out the channel by zapping it with high voltage that destroyed the input circuit of the channel. Often there are bypass capcitors right at the input which short out. If this is boiught used, take to a repair shop and if new, exercise your warranty. I suspect they removed the nut from the connector to mark the dead channel.
Aug 18, 2011 | Kustom KPM4080 PA Amplifier/Mixer
MY WIFE WAS PLAYING THE ORGAN THIS MORNING, SHE HEARD A SNAPPING SOUND AND THE KEY BOARD WENT DEAD UNTIL YOU GET TO THE NEXT TO THE LAST C ON THE LEFT SIDE OF THE KEY BOARD. ALSO THE VOLUME LOWERS ITSELF...
Servicing is obviously required. By the symptoms, I think a bad electrolytic capacitor is the likely culprit. One other possibility is contamination, including an insect has gotten into the works and causing a short at some point.
Nov 15, 2010 | Music
No sound from Yamaha Electone HS-6
First check if you get sound from the headphone jack.
Do you hear anything as the power comes on from the speakers..? A slight bump?
A lot of these dead audio things can be traced to a failure at the expression pedal. often these use a light dependent resistor and the illuminating lamp burns out. This is all down by the pedal.
Many of the Yamaha organs, including the FX20 I have, have circuitry that checks that the power amp has DC balance before a relay closes to connect the speaker. A failure in the amp can cause dead sound as well.
Jan 12, 2010 | Yamaha Music
Hi, Yamaha Electone HS-4 NO SOUND
j have had the some problem on hs 7 . The relè not work probably you have a cold o breaked joint on power amplify integrate or it is broken.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
119 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
