Question about Desa International Remington 14" Electric Chain Saw Assembled 1.5 Peak
I have an 14" electric Chain Saw. What type is Oil do I use?
    Sergeant:
  • 384 Answers
You can purchase chain oil, or if you like any 30 weight oil will do.
Posted on Jun 26, 2009
MCC1514 oil
Most any chainsaw , chain oil . Just so it is not dirty and will not clog the oiler.
May 17, 2014 | McCulloch 14" Electric Chain Saw Mcc1514
I have a Remington 14' Limb n' Trim electric chainsaw. There is an oil reservoir (I think - it has a little rubber cap) and I am not sure if it is for motor oil. If it is, what type of oil should I use?
jmccabe2465-
The reservoir is for bar chain oil, which all chain saws require to allow the chain to operate smoothly and reduce heat build-up from friction.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Remington Electric Chain Saw
I inherited my father's EM250, 14" electric chain saw. It needs oil. What type of oil should I use?
Bar and chain oil available at most home centers and hardware stores is the only oil needed by any electric chainsaw.
Lou
Sep 15, 2010 | McCulloch Garden
What type of oil does a remington chain saw use?
Regular bar/chain oil available at home centers, hardware stores, and saw dealers. Hope this helps!
Aug 14, 2010 | Desa International Remington 14" Electric...
Remington 14" Electric Chain Saw Assembled 1.5 Peak: I just wanted to know what type of oil to put in t...
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
May 17, 2010 | Desa International Remington 14" Electric...
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
I replaced the chain on the poulan el 14 and when I would tighten the aft bolt this caused the chain to begin to stick when I would manually move the chain
Poulan "1420 Electric Saw Type 2" (may not be your saw)http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
Open the link; Click "View the illustrated parts list [GO]" link; open the "Illustrated Parts Lists" folder; Click "Chain Saw Assembly Type 2". Compare items 20 and 21 with your saw, the flared portion of 20 should be toward the clutch cover not the engine and on the clutch side of the bar. The only other thing that comes to mind is item 23 should fit into the hole on the bar (the bar should be tight against the oiler channel; engine side of the case.). HTH
Lou
If these are correct please add comments below and we will continue.
Dec 29, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
What type of oil do a Remington 14" 1.5 electric chain saw use
Use any commercial bar oil. It is available at most home centers and hardware stores. I use the Ace Hardware brand. Bar oil contains tackifiers to attempt to keep it on the bar and chain, the parts that need lubrication. HTH
Lou
Oct 10, 2009 | Remington 16" Electric Chain Saw
Do not have manual and need one. Do not know what type of oil it uses.
According to the manufacturer, "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." I will need the actual model number of your saw (it should be loacted on the saw it's self) to see if I can find the manual for you. I hope this helps so far...
May 27, 2009 | Remington Electric Chain Saw
Desa International Remington 14" Electric Chain Saw Assembled 1.5 Peak Logo
228 people viewed this question
Top Desa International Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Desa International Garden Expert? Answer questions, earn points and help others
