Question about Brother HL-2170W Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
I'm trying to see what's wrong with my Brother HL-2170w printer. It was working fine yesterday, and now , for some reason, all 4 buttons are flashing and the printer won't print anything!
Toner LED: Flashing Yellow
Drum LED: Flashing Yellow
Error LED: Flashing Red
Go Button: Flashing Blue
I've tried cleaning the corona wire, removing and replacing the drum, removing and replacing the toner cartridge. Nothing seems to work. Please help!
  • ernest931 Jun 26, 2009
    Well that's really disappointing... I purchased my printer December of 2008, and I've really only printed about 30 pages total in the past 6 months...
    Thanks for your help.
    In case you were wondering, it looks like it was a fuser failure.
    President:
  • 2,306 Answers
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Posted on Jun 26, 2009
  • Craig Gillette
    Craig Gillette Jun 26, 2009
    Brother has 1 year warranty, so you should be able to fix it for no charge. 1-800-276-7746.
  • Cathy Dec 14, 2010
    We have three of these printers and after a power outage..all three had this same issue, all four LEDs flashing and when press and hold the power on the Toner LED stayed on.. and the unit was not heating.. I would then assume the Fuser is defective since its not heating. by fluke was found that had to reset the computers they were plugged into and if networked.. reset the network connection either by time or manually and wait a bit. they all came back online. as a tech I personally found this very unusaul as even when the printer was not plugged into the network via ethernet cable, the LEDS still all flashed.. this must be something with sensors and the computer is in control somehow.. I don't like it myself...but hey they are working.
See page 82 of the PDF in this link:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_5340D_5370DW_5370DWT_EN_1750.PDF
Posted on Sep 22, 2012
fdlixboy
  • 79 Answers
SOURCE: Brother printer HL-2070N
go to the start of your computer and find the control panel and when you see the ad and remove program click it and and you see the currently install files find words brother printer HL. click it and remove after that please restart your computer din insert your brother printer installer cd into cdrm and install again maybe your current printer driver some files is missing, or reformat your pc using os/operating system and install the printer again make sure your printer have a load tuner or ink. thank you
Posted on Jul 04, 2009
  • 11 Answers
SOURCE: Remove toner catridge from Brother 2170W
Open the front of the face. Pull out the catridge and drum assembly carefully. Thier should be a yellow tab on the toner catridge press down and the lift the toner catridge out. Replace and reseat in printer.
Posted on Sep 09, 2009
SOURCE: My Brother HL-2170w laser printer is saying it is
http://www.metacafe.com/watch/1913451/low_toner_on_a_laser_printer_laser_printer_hack_how_many_pages/
Posted on Nov 07, 2009
SOURCE: cannot remove toner cartridge from Brother HL 2170W
Had same problem. The instructions don't tell you that it is not just the cartridge that needs to be pulled out but the frame (black metal thing) inside which it sits. The whole thing pulls out. Of course, you have to press the green tab too.
Posted on Dec 28, 2010
ichiboi
  • 78 Answers
SOURCE: How do i get the
Hi Lorne-
Here's the step in pulling out the cartridge of your printer:
1. Open the front of the face.
2. Pull out the catridge and drum assembly carefully.
3. Thier should be a yellow tab on the toner catridge press down and the lift the toner catridge out.
4. Replace cartridge and reseat in printer.
Hope this helps,
Good Luck!
Posted on Mar 10, 2011
How do I reset the Drum light on my Brother HL-2170W laserjet printer? I changed the drum already.
Open the front of the printer. Hold down the white button on the left until all 4 lights come on. Close the front cover. Voila.
Mar 02, 2012 | Brother HL-2170W Laser Printer
My brother HL-2170W have a flashing error and drum light. When the printer starts up, its stops in the middle as if a paper is stuck but I can't find anything.
Hi There,
The Drum LED and the Error LED alternates turning on and off.
Meaning of LED Indication
Drum error:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Please click on YES if this helps,
Thanks,
Vikroks
Mar 23, 2011 | Brother HL-2170W Laser Printer
I have a problem that a printer brother 2170w wereve the leds error and drum are blinks. please i need help
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds.
Once all 4 LEDs are lit, release the button.
Make sure that the Drum LED is now off.
Feb 11, 2011 | Brother HL-2170W Laser Printer
How do I find the page count on Brother 2170W laser printer?
you can see the page count by printing the "printer settings page."
read page 57 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf
Jan 27, 2011 | Brother HL-2170W Laser Printer
My HL-2170W has a flashing drum light and won't print. I replaced the drum but still having the same problem. Now what?
Open the front door
complete instructions can be found here
Dec 28, 2010 | Brother HL-2170W Laser Printer
There was paper jam, i cleared it but now it still flashes the "error" light. what do i do? i've pressed the button, but it still flashes.
Hi Good day!! Turn off your printer in about a couple of minutes and then turn it back on. see if the error is still there..
Thank you for using FixYa
Nov 19, 2010 | Brother HL-2170W Laser Printer
Drum light flashing on brother printer hl-2170w. what needs to be fixed?
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
Nov 05, 2010 | Brother HL-2170W Laser Printer
I relaced the drum yesterday on my HL-2170W but the drum light keeps flashing - how do I get it to remain off?
Open the front door
Oct 31, 2010 | Brother HL-2170W Laser Printer
I installed a Brother HL-2170W a month ago and it worked fine on my wireless. Now I cannot get a wireless connection. Can you point me in a direction?
Please check that, can you go online with any wireless computer,if you can go online with that, then try to reconnect your wireless printer again (if can't go online then check wireless router)
Hope it can resolve your query
Thanks for using Fixya
Apr 03, 2010 | Brother HL-2170W Laser Printer
IP address
If you lose the IP address you can reset the network card.
Since the machine no longer has an IP address, you MUST be connected with a network cable.
1. Turn the power off
2. Press and hold the "go" button (the blue one on the front)
3. While holding the Go button, turn the power back on.
4. Keep holding the Go button until all 4 lights are on.
5. Release the "Go" button and press it 7 times quickly.
This will reset the network card and you should get a proper wired LAN IP address.
Thanks,
Pat
Mar 31, 2010 | Brother HL-2170W Laser Printer
Brother HL-2170W Laser Printer Logo
6,440 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
