Question about Pentair Minimax NT Heater
I shut off the gas to the unit and the power.i
I shut off the gas to the unit and the power for 1 week. i changed the copper heat exchanger. when i tried to fire the unit the fan comes on but the heater doesn't fire. the service light comes on. a service guy said i need the following, flame sensor replaced, thermal fuse replaced, and no voltage to gas valve. the unit was fine prior to replacing the heat exchanger. does this seem correct all these would go out
  • 83 Answers
No, that does not seem correct. If all you did was replace the heat exchanger, then tried to start it up, how could everything go wrong. Unless there was another issue with the heater. Not too many people change out the exchanger, unless corrosion has caused a leak there What you CAN try to do is reset the heater. To do this, turn off your heater first-at the toggle switch inside the right hand side door, then turn off the circuit breaker to the heater, wait about 5 to 10 minutes, then reverse the order. Circuit breaker then heater, if you have the digital display, you will see flashing codes, this is the computer resetting, then you should see the normal display. Try starting the heater again. If it still will not fire, let me know if you receive an error code. Also, check to see if the temp the heater is reading is close to that of the actual water temp.
Posted on Jul 01, 2009
Heil epm36f19a1 runs but no heat
Fan relay is stuck among other things. The thermostat turns on the combustion air fan and puts power to the spark unit. If the burner comes on after the temperature in the heat exchanger rises the indoor fan will then come on. After the thermostat comes to temperature the power to the gas valve which shuts off the burner. Then after the heat exchanger cools a bit the indoor fan will stop. That's the sequence of events. look at the switches that control the fans. There is a wiring diagram somewhere on one of the panels that access the unit for service.
Mar 06, 2013 | Electronics - Others
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Nov 22, 2011 | Dayton Gas Furnace Heater
Flame comes on, fan runs after a few minutes then unit will shut down, will sit a few minutes then sart back up, seems to be short cycling all happens within 8 minutes. \r\nmodel QVB-2505 PS. What...
there are limit sensors around fire box.you need to remove front cover.if flames are coming out of fire box there's a restriction in air flow. on older furnace could be fan belt . air cond. coil could be pluged up are all the vents open and have good air flow?you check limits by pulling one wire and check with ohm meter.there normally closed and open when too hot.most limits around fire box don't reset them selves.on some draft inducers there's a limit if it is tripping then theres a vent problem.theres also a limit on the fire box (heat exchanger) that may or may not self reset.
Jan 12, 2011 | General Heating & Cooling
How do I set the heat at 75 with no fan mode. I don't want the fan to come on once the room reaches 75
Hi, there is no way that this can be done. The fan is controlled by several different parts for the furnace to run properly. If you are saying that the fan continues to run after it reaches its set point, this is normal if it only runs for about a minute and 1/2. This is to cool down the heat exchanger. If it continues to run all the time after reaching its 75 degree set-point, you have a fan relay that is sticking internally, or a high limit switch that has failed and depending on how old the unit is, it may be what is called a combination fan/limit control that has dirty or burned contacts which will keep the fan on. What I am trying to say, is when your unit reaches the temperature you want, the fan should only run a short time as the limit controls are there to shut it down from a setting on the fan control that is preset by the factory. If you can give me more information on your unit such as model, serial, name of unit, and if it is a gas fired central heat and air unit, or heat only, a heat-pump ect. would be of a big help to determine what controls you have on this unit that is keeping the fan on. Leave this info in the comment thread for my user name, and I will get back to you.
Sincerely,
Shastalaker7
A/C, Heating, & Commercial Refrigeration Contractor
Jan 12, 2011 | Heating & Cooling
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
Heat would not come on and fan would not cut off even when thermostat was set to off. Took off the outside panel of the unit and red light was blinking 7 times - rollout switch fault. Since fan would not...
this means that the rollout switch was tripped by a flame coming from burners. could be a plugged fue or bad inducer motor, or a bad rollout switch. the fan will not shut off as a safety feature it keeps running incase the heat exchanger is to hot to keep a fire from starting. it will shut off after disconnecting power and restarting everything. watch the flames from burner when it lights to see if the actually roolout of the burner box toward the rollout sensor.
Dec 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My Carrier 58SXC keeps running but with no heat. The fan will not shut off. I checked the thermistat and it is not in the on position. Any suggestion? Thank you
Hi, it sounds like the fan control is stuck on or faulty. This controls the fan in the heat position. What happens is on a call for heat at the t-stat, the burners come on then after a delay, the fan control set at a preset temperature, brings on the fan. When the T-stat and room are up to the desired setting, the T-stat sends a signal back to the main gas valve to shut off. The fan is supposed to run for 45 seconds or so to cool the heat exchanger down and shut off the fan at a preset temperature.It is called and fan/ limit control. Looking at the furnace, depending on the unit, you will see a rectangular box some with a button on them that says manual/ auto, that has a probe inserted into the fire box. It rotates and has a temperature dial with settings on it from the factory. You can see them by removing the cover.There are several types, but you will know it when you see it. You can turn off the power and gently pull it out and clean with a brush. Gently rotate the dial back and forth and hear it click, this is what shuts the fan off.It may not have the dial type.If its a Honeywell it will. After cleaning it, reinsert and restore power. Run it through a heat cycle and see if the fan stops when it is supposed to.If it continues to run, you will need to replace it.You can find one at a appliance parts house or air conditioning supply.Read the instructions when installing. The Honeywell type has a metal strip that has to be cut before you operate it for 24volt control. If you don't, it will send 120 volts through the low voltage controls, burning them out.Remember how it is wired, or draw and mark your wires. Its really not to difficult, but try and clean it up first. It may be ok if you do. They do tend to stick, and lets hope that will solve you're problem. Please let me know, and keep me posted. Good Luck,
Shastalaker7
Dec 08, 2009 | Heating & Cooling
Furnace runs about 1 minute, then total shutdown
What type of gas supply line do you have? Is it black pipe or copper? If it is copper, there can be a film like substance that builds up on the inside of the copper. The debris will the get caught in a pre screen where the supply enters the valve thus cutting the supply of gas to the unit. Also, the thermocouple may be bad. You didn't say that you replaced it. Try replacing it as well. Also, you could have a limit switch turning the system off and thus cutting the gas off completely but it is highly unusual for the pilot to be cut off as well unless the pilot is being blown out when the gas is shut off. Also, turn the unit to fan only without calling for heat. Using a flame of some sort, put it into each baffle of the heat exchanger. If your flame is being blown around in one of the baffles, then you have a hole in the heat exchanger and what is happening is that the roll out switch is cutting the unit off and the air still moving through the heat exchanger is blowing the pilot out. I have seen this actually happen. If your furnace is in excess of 15 years old, it does need to be checked for possible holes. If it is in excess of 25 years old, it is a huge possibility that the unit has already developed a hole. If you feel hair coming out of one of the baffles, then shut the unit down immediately and have it replaced!
Apr 05, 2009 | Heating & Cooling
My Whirlpool furnace (WFCU125D20-1A) is not working. The indicator light is blinking 3 times meaning presure switch. This has hapened in the past.
1.when you turn off power to the unit and retry with power after two minutes does the unit fire up and is there blue flames or is it more white or yellow This could be a blocked intake or exhaust vent also gas pressure could be fluctuating from another gas appliance firing. 2. does the flame jump when the main fan turns on this could be a cracked heat exchanger which is the part where the flame blows in. let me know if this help
Jan 10, 2009 | Heating & Cooling
Pentair Minimax NT Heater Logo
372 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
