Question about Toshiba Satellite A45-S250 Notebook
Windows won't start
My toshiba satellite A45 wont start windows . This is the message
I DE # 0 error
Intel (r) boot agent
fe v4.1.10
(c) 1997-2003 IC
pxe-egi- Media test failure. Check cable
pxe-mof exiting Interl boot agent
Insert system disk in drive
Press any key when ready
  • ravenplay Nov 08, 2007
    I never dessemble the laptop. I was runing an antivirus and that day died. Is possible that is the hard drive ?
  • 117 Answers
Reassemble and check for all
Posted on Nov 06, 2007
IDE 0 error
Can you open the BIOS setup at boot? Look for the primary HDD, is it listed? If no, unplug, remove battery, You can try to reseat the HDD, perhaps it's not making a good connection? Or perhaps it was damaged in shipment? Was it packed well? You can remove it and test to verify it's working properly.
Feb 20, 2013 | Computers & Internet
Can't boot my toshiba A50 laptop. Error code IDE #0 on display.
The hard disk is not responding to the motherboards commands - the disk is dead. Replace it and reinstall Windows using the recovery cd.
Jul 17, 2011 | Toshiba P000392200 - Satellite A40, A45...
I got a Toshiba Satellite A15-S1292 at a yard sale and immediately upon booting I received this message: IDE #0 ERROR Intel(R) Boot Agent FE v4.1.09 Copyright (C) 1997-2002, Intel...
Hi Jon.
Go into the BIOS confuguration by pressing the F2 key as the laptop starts up and set the BIOS to its default configuration. Save the changes by pressing the F10 key or save in the BIOS menu. The computer will restart so see if that has made any difference.
If you still get the same IDE #0 error then the hard drive is ready for failing. A replacement hard drive will not cost much at all.
Seeing as you have only spent $20 on the laptop in the first place you have got yourself a bargain there. Spend a liitle money on a new drive and OS then you could have a fully working laptop.
Jun 07, 2011 | Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Toshiba satellite error code ide #0 error
IDE #0 is where your hard drive connects to your computer's motherboard. You may be able to connect your hard drive to IDE#1 or you will have to have your motherboard replaced.
Jun 28, 2009 | Toshiba P000392200 - Satellite A40, A45...
Toshia IDE #0 ERROR comes on the screen about 2 mins after starting then as follows is on the screen. .Intel (R) Boot Agent FE ver 1.10.PXE-E61 Media test failure check cable. PXE-MOF:Exiting Intel Boot...
This error is telling you that either one of three things have happened. 1. Your hdd cable has come loose or failed. 2. Your HDD has failed, or 3. the IDE controller on the motherboard has failed. You can check problems by trying a known good hdd in place of your old hdd. If bios sees it then it is the drive itself that is bad not the cable or controller. If it does not see the good hdd then try replacing the cable. If this fixes the problem then remove good drive & replace with your old hdd. Problem should be solved. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Toshiba (MK8034GSX) 80 GB IDE Hard Drive
My Satellite A40/A45 Series won't boot up.
If NTLDR is missing, you will need to do one of two things:
1) follow this link and follow instructions to create a NTLDR boot disc and get back up and running
2) boot to Windows CD and repair Windows installation
Hope this helps - remember to rate :)
Sep 25, 2008 | Toshiba P000392200 - Satellite A40, A45...
sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Aug 28, 2008 | Tablets & eReaders
If the fault comes and goes, it may be loose cable connection or dry solder joints.
May 15, 2008 | Acer Aspire 3680 Laptop
Toshiba Satellite A45-S250 Notebook Logo
343 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
