Question about Maytag Neptune Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Posted on Sep 29, 2010
My Maytag Neptune washer is extremely loud during the spin cycle and the detergent dispensing door is broke, How much would I be looking at out of pocket to get it fix or would it be cheaper to replace it...
The loud noise during the spin cycle is probally due to a bearing failure. Not sure how much it would cost to fix, but Maytag does not sell you the bearings but would sell you a new wash tub with the bearings installed for over $600! Add the labor costs which would be a lot since the machine needs to be taken apart to install a new tub, and you would be ahead of the game getting a new washer.
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Our neptune front-loader has become extremely loud during spin cycles, you almost need hearing protection, otherwise, it works great
Ball bearings have worn out. Replace as a set. Replace Water seals in the drum. Check the bearing shaft for any scrub marks. Check bearing housing. Fix new bearings now
Apr 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaks water and is abnormally loud during spin cycle
Sounds like the bearings are broken. This is a serious issue and may be quite expensive. If your appliance still under warranty, contact the manufacturer for assistance. If not, don't be afraid to ask the customer service if they can provide some assistance to replace your washer (as the repair will be quite expensive), perhaps the manufacturer may be able to provide a rebate or something like that if they appreciate you as customer.
Good luck.
Aug 31, 2009 | Amana Washing Machines
Mah3000 aww making extremely loud, clanking, grinding during spin
Gotta admit tonytools albeit not cheap has the best easiest tool to do that rough difficult repair.
Jan 01, 2009 | Maytag Neptune Washer
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Washing Machines Logo
2,139 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
