Question about Homelite Mighty Lite Lawn Trimmer
Pull cord stays out, won't retract. I took apart
Pull cord stays out, won't retract. I took apart and rewound. works for a few pulls, then remains out again.
  • Anonymous Mar 14, 2014
    pull cord won't retract
  • 59 Answers
The end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Posted on Jun 27, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
Am trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like.thanks!
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.
What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.
I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.
Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
Apr 05, 2010 | Generic Memory Mini Retractable USB...
The Pull cord was jamming. I took it apart and
the rope and spring both have thier respective place in the housing for thier mountings they can be rewound by hand and reassembled with success,hint oppisite end of spring has a anchor point on the housing while one end is secured by a cup like screw mounting,to create the retracting force for retrival of the pull start rope its tricky if haven't done it before but you learn by trying Good luck Steve
Oct 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
909 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
